January 09, 2025, 12:26:33 AM *
Author Topic: 750 motor to 900 swap  (Read 1705 times)
Hank
« on: June 06, 2008, 01:00:08 AM »
I'm curious as what this involves.  Is it as simple as swapping the motors with new (or re-jetted) carbs?
Bike in question is a 2000 Monster 750.
'00 Monster 750 Dark
Current mods: K&N and removal of the intake silencers,  AFAM 14 tooth front sprocket.  Termignoni high mounts <---Best mod yet!, Evoluzione slave cylinder,
NEW: removed dinky plastic covers and emissions canister for moar n00dity!
"I like my women the way I like my roads; with plenty of curves!"
Omnipotent Potentate
Personal Pretext
« Reply #1 on: June 06, 2008, 05:11:18 AM »
Well make sure you get a carby 900 otherwise you'll have a bunch of problems.
Beyond that, I don't think it's much more than working out your fueling.  Never done it, but from what I've read it's pretty close to plug n play.
foiegras900ss
« Reply #2 on: December 01, 2008, 09:25:00 AM »
I am brand new here, but I think my Monster started out as a 750 and the guy told me it has a 900 motor in it. It looks like a plug and play thing from what he described it to be. I still need to verify if my Monster is a 900 motor because it doesn't seem as fast as my 900SS with 39 FCRs/Lighten Flywheel/Exhaust.  There is a MAJOR power difference when I rode both of mine so I'm skeptical about my Monster right now.
« Reply #3 on: December 01, 2008, 09:27:12 AM »
It could be you ended up with a small valved motor which would be less powerful than your SS.
Is the monster dry clutch?
Personal Pretext
« Reply #4 on: December 01, 2008, 12:45:16 PM »
Well, you've also got aftermarket fueling, exhaust and lighter flywheel- which can make a lot of difference.
But like DP said - if it's got a dry clutch, then it's probably a 900.  If it's wet, then odds are it's still 750
greenmonster
« Reply #5 on: December 01, 2008, 04:30:27 PM »
You could measure exhaust pipes outer diameter.
900 is 40mm, 750 at least 3mm thinner.
M900 -97
MTS 1100s  -07
