Front chain guard - what is it good for?
Started by stopintime, August 03, 2010, 12:28:28 PM
Frankie goes to Hollywood?
It looks ugly, hides my ERV3 chain, makes it harder to clean that area. Anything else?
Will it in any way actually protect me from a broken chain?
Ducatl
I think it's more so you don't get anything(body parts included) snagged and pulled through the sprocket.
I see people run without one all the time though
pennyrobber
...what is it good for? ... absolutely nothing.....
I took it off because it looks much cooler without it.
battlecry
Get a prettier one.
I like mechanisms as much as the next guy, but exposed hard moving parts so close to my parts doesn't appeal to me.
DarkStaR
#4
I took the rear one off, and wanted to take the front one off also; however, I noticed that every once in a while the inside of my heel hits it, or it hits the inside of my heel.  If it wasn't there...
I'd like to change it to one that lookes better though, but if it make contact with the inside of my heel, it can't be CF.  Amuminuim sure, but that's not too common.
My rearsets came with a large metal heel guard, which btw doesn't protect my heel. If my heel hits anything, it's the swing arm.
if you go down and get your toe pinched and the wheels still spining, it will save whatever your wearing from getting caught.
aside from that nothing. i only put mine back on because i hit the track this year. otherwise i would not have it.
mattc7
Quote from: He Man on August 03, 2010, 02:23:58 PM
you don't need it at the track....
BK_856er
Momentary backup if your front sprocket bolt/s work loose?
BK
DucHead
I have a DP carbon fiber front chain guard that has never fit right.  I trimmed it a bit and it still rubs the chain.   >:(  I think I'll remove it one of these days.
Chain lube sling
As the chain turns around the sprocket, the change in direction causes sling.
Your leg will be covered in lube after you do the chain.
Cleaning the chain harder?  It's that hard to use a hex wrench?
badgalbetty
I raced NHRA drags 2 years ago. Without chainguards you won't pass tech. It is required at the track here in Portland Ore.
DucHead
#12
Quote from: ducatiz on August 03, 2010, 04:08:06 PM
Chain lube sling
???  Hex wrench?  Maybe you ride around backward, but 98% of my sling ends up on the cases around the drive sprocket.
Quote from: pompetta on August 03, 2010, 05:10:25 PM
hex to remove the guard
and yes, 98% of the sling goes there
the other 2% will go on your leg.
mattc7
Quote from: badgalbetty on August 03, 2010, 04:34:29 PM
Chain guards on the swingarm are required at the track here.
the "front chain guard" otherwise known as a sprocket cover, however is not, at least at NJ Motorsports Park
