January 04, 2025, 11:48:05 PM *
News: Please Help
Author Topic: tail light only turns on when braking?  (Read 1609 times)
grinningevildeath
« on: June 06, 2008, 09:31:42 AM »
tail light only turns on when braking? It does not ignite when the bike is running or put into park. just when brakes are applied. any suggestion would be appreciated. thanks
Omnipotent Potentate
Personal Pretext
« Reply #1 on: June 06, 2008, 10:50:17 AM »
This the stock bulb?  IF so it's got 2 filaments in the bulb - the one for the runnign light might well have just burned out. Occasionally the connections can work loose back there too - easy to check either/both
meano_lover
« Reply #2 on: June 06, 2008, 02:13:01 PM »
check to see if you have power there. you should have one ground, one brake power, and one running power. check if the bulb is good first though, then check through the wiring. then trace backwords to where the power should be coming from. good luck!
'97 m900; stage 2 carbs, filter pods, remus carbon exhaust
CRASH!
« Reply #3 on: June 07, 2008, 05:24:33 PM »
If the running light filament on the bulb is blown, you'll clearly see it if you pull the bulb and look at it.
That filament is very short lived on Monsters. There's a lot of vibration and since that filament is always hot, it's more fragile than the brake filament.
Many of us have gone to LED bulbs after getting tired of replacing 1157 bulbs every few months. Others haven't found it to be a problem Undecided  I'm in the LED camp.
But as others have noted, corrosion on the contacts and general sloppy misalignment of the bulb may also be the cause of your symptoms... but my money is on the filament Wink
bdfinally
« Reply #4 on: June 08, 2008, 04:00:06 AM »
and go to an auto parts store to get it...those dealership prices are insane.
