Question about GoPro Camera use
Started by DoubleEagle, August 13, 2010, 08:20:35 PM
DoubleEagle
I bought a GoPro Video Camera to video some rides .
After I got it I'm wondering if it will stay suctioned on top of my Helmet while riding or those who have successfully used one , where is or how is the best way to attach one for aggressive riding ?
Dolph     :)
DoubleEagle
Quote from: bobspapa on August 13, 2010, 09:12:33 PM
use the velcro mount ;)
OOOOOO KKKKK, but to where do I velcro it ?
Top of Helmet ?
Gas Tank ?
Dolph    :)
zip tie it to the frame on the side
DoubleEagle
Quote from: Raux on August 13, 2010, 09:33:20 PM
That sounds like a pretty good idea Jerry.
I'll see if that will work better than BP's suggestion.
Dolph     :)
Strap mount on the chest (not moving much, as your head would)
Front fender (low down makes cool videos)
Seat cowl (either direction makes interesting images)
By the radiator (includes the fork action)
Just don't mount it on top of the tank, including the speedo, it might be used as evidence  [bang] (has happened here)
DoubleEagle
Quote from: stopintime on August 13, 2010, 10:37:21 PM
Thanks for that info. Lars, especially about the speedo.
Dolph     :)
a Gopro lens does not rotate (AFAIK), so if you mount the camera in any position other than straight up, your images will be tilted. In Movie maker you can rotate your down loaded images but only 1/4 turns so most Gopro users mount the camera on the vertical or use the angle attachment..... and most do not trust the suction cup attachment on anything less than a really flat surface. playing with camera angles  is fun so mount it anywhere you think the view would be cool.
I purchased a Drift camera just so I could rotate the lens.
<object width="400" height="266" ><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://www.facebook.com/v/409683747004" /><embed src="http://www.facebook.com/v/409683747004" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="400" height="266"></embed></object>
There is a special curved sticky plate for helmets and the suction cup sucks on monsters since theres very few places it will fit. (too much curvature on the helmet and msot parts of the tank. Alternative = keep it on the bike.
heres mine, its kinda jacked to the right cause i was trying to get the memory card out. but its very easy to access.
hmm i still have some tape from my previous trackday!!!
Airborne
Get the gopro tripod 1/4 20 adapter and a manfrotto super clamp
I use these on rocket sleds at work, 200mph, no problems.
2007 Monster S2R, Vespa GTS 300, 2023 Triumph Tiger 900 Rally Pro, Vino 125
ok 200, big deal, what about 140?  ;D
derby
Quote from: Airborne on August 14, 2010, 04:31:38 PM
i want to say the gopro guys (successfully) tested their suction cup mounts on indy cars in excess of 200mph.
-- derby
'07 Suz GSX-R750
DoubleEagle
Quote from: derby on August 14, 2010, 04:58:54 PM
Derby, do you know where or how they mounted it ?
Dolph     :)
DoubleEagle
Quote from: He Man on August 14, 2010, 11:02:04 AM
He Man, that looks loke a good place to put it .
Dolph   :)
I've seen some suggestions that a lanyard is a good idea just in case the mount comes loose.
