April 29, 2024, 09:27:30 AM
Lowering a 620 - short friend (girl) needs advice.
Topic: Lowering a 620 - short friend (girl) needs advice. (Read 2226 times)
S2R 800 '07
June 06, 2008, 02:14:52 PM »
Is this possible? She's on her toes and is planning to rebuild the seat. Can the bike be lowered as well? How?
nats
S2R1000
Re: Lowering a 620 - short friend (girl) needs advice.
June 06, 2008, 03:06:08 PM »
The answer is Yes, you can lower the 620 with many mods. I did several as I needed more than the standard lowering as I had to reduce the height by more than 2". The only constraint will be the variance between the bumps and exhaust at the bottom of the bike. The feel of the bike too will deteriorate as you go lower.
The best investment would be the lowering link that takes off about 1.23" max. You can easily get one from Jeff at Monsterparts.com and keep the OEM link. Alternatively, if there is a machine shop nearby, you can cut the OEM link and rethread. I find these loweing link option much better than cutting the foam off the seat as the OEM seat pretty comfy (IMO). If she is relatively light, you may also soften the springs at the rear a tinny bit. Better still - get riding boots with a thick sole (the Daytona Ladystars are some of the many good choices available and pretty steeply priced too but worth the investment).
Once your lady pal gets used to the bike - just a bit of support during stops, even with just a toe is all she need. But until then, reducing the height to a level she feels comfortable helps tremendously in building confidence and pleasure with the ride.
Been there, done that......
m1moto
June 06, 2008, 03:13:18 PM »
There is also a lowewring link from Eastern Cycles
http://www.easterncycleducati.com/ecdparts.htm
As far as I know if you lower the rear 1" then the front must also be lowered by 1". You will need to drop
the triple clamps to make all things equal.
Cheers
Marcel
2006 S2R1K | Red + White | Full Carbon Arrows
http://freshbrand.com/
S2R 800 '07
June 06, 2008, 03:40:02 PM »
I will forward this to her, thanks
Is the 695 seat, which is (?) lower than S*R seats, also lower than the 620 seat?
Omnipotent Potentate
Personal Pretext
June 06, 2008, 06:16:56 PM »
620s had a lower seat than other monsters of there era. I'd guess that the seats on the 695 are identical to 620 seats.
If you do opt to shave the seat, look in the How To Section. MangledBug recreated her detailed step by step shaved/gel seat tutorial.
If you drop the rear you don't *have* to drop the front - but not doing so will increase the rake and trail makeing the bike less willing to turn in. So, you should do both.
As nats noted, the more you lower it, the less the travel the rear suspension will have available. The further you go, the less there will be. Too far and you're going to crap up the ride
crazy bike girl
aka msincredible
June 07, 2008, 07:58:30 AM »
Also have her check out our
Short Rider FAQ
photo FAQ
S2R 800 '07
June 07, 2008, 08:11:42 AM »
Quote from: msincredible on June 07, 2008, 07:58:30 AM
Short Rider FAQ
You mean I should search before I ask?
Thanks, that will be a perfect place to work from
El Matador
Do I need knee pucks for my
June 07, 2008, 08:45:26 AM »
Stopintime, this might be what you're looking for, not only lower, but also more comfy
http://ducatimonsterworldwide.org/index.php?topic=2513.0
