January 20, 2025, 05:30:31 AM *
Author Topic: chain swap  (Read 1306 times)
CougarSlayer
« on: June 07, 2008, 02:23:21 AM »
Well I went to the dealer to see what can be done to swap out the chain it was recommended to swap it now that all links are are not aligned with the others.  Basically, it seems like some of the links are bent.  It was also recommended to swap out the sprockets as well.  I was just wondering what was the normal practice to determine one when the chain needs to be replaced  and two do you normally change the sprockets as well.  To me if the chain needs to be replaced it would only make sense to replace the sprockets as well.
-panthro
cc's are still 992
A.duc.H.duc.
944 ist sehr gut!
« Reply #1 on: June 07, 2008, 03:46:48 AM »
What they are probably talking about is that the chain has stretched unevenly, so you will have different distances between link pins. The chain should be replaced.
It is pretty common practice to replace sprockets if the chain has gotten really bad, because the sprockets generally get pretty well fubared by a bad chain.
If your chain has been like this for any length of time, you probably need the sprockets.
On the other hand, your sprockets could be totally fine.
If you have stock sprockets, and money isn't a huge issue for you, I'd recommend getting new sprockets, and going up 2 or 3 in the rear. You will get the same effect as the 14t front sprocket, and your chain will last longer.
Justin
