April 27, 2024, 03:23:48 AM
"Battery keeps dying" 2007 M695
Topic: "Battery keeps dying" 2007 M695 (Read 7718 times)
WednesdaysChild
August 28, 2010, 11:44:30 AM »
I have looked on the forums for a similar problem. If there is a thread containing this issue, please direct me there.
I have an 07 M695 which rarely has given me any trouble. I am no pro, but a fairly decent DIY mechanic and perform all maintenence from oil changes to valve adjustments. I figure if there is a forum with instructions I can do it.
I have never had to change my battery since purchasing the bike new and replaced it 5 weeks ago when my bike would not start. The bike would attempt, and all lights and gauges worked but not enough power to turn the starter. Nor would the battery hold a charge when attempted to trickle charge it. After nearly 4 years in the PX AZ heat I figured it was time for a new battery. New battery, problem fixed. Worked great for a week or so and again I found I had a dead battery. (note, I ride my bike to work 5 days a week, 600+ miles) Battery charged up fine overnight, but I replaced the regulator with a new one figuring my bike was not charging my battery. Again it worked fine for a little over a week and the battery is again dead. It will charge up and then work for a little over a week and die again.
Does anyone know what is likely the culprit and how to diagnose this.
New battery
New regulator/rectifier
All fuses are fine
What wires specifically should I be inspecting and measuring voltage.
Thanks in advance
Re: "Battery keeps dying" 2007 M695
August 28, 2010, 12:12:27 PM »
A quick voltage test at the battery would be a good start.
You should see 13.5 -14.5 volts at about 3K rpm
WednesdaysChild
August 28, 2010, 12:30:53 PM »
Thanks for your reply
Before firing up the bike the reading was
12.75
With bike running at 3K reading was
12.35, dipping down to 11.~ during the ignition start up.
I just finished charging the battery yesterday morning so I figure that's why it is still 12V.
August 28, 2010, 12:48:51 PM »
Quote from: WednesdaysChild on August 28, 2010, 12:30:53 PM
12.75
It's not charging,
There is a thread somewhere that describes how to measure the voltage coming from the stator. I did a quick search and came up empty.
I'll look again.
August 28, 2010, 12:52:47 PM »
Found it....
This should get you going...the output wires are the yellow wires going to the regulator
http://ducatimonsterforum.org/index.php?topic=14261.msg246555#msg246555
WednesdaysChild
August 28, 2010, 01:18:24 PM »
Thanks for the info, I will check out that thread,
I found this thread and have been following sujij's advice
http://ducatimonsterforum.org/index.php?topic=38742.0
when I unplugged the regulator/rectifier and measured the voltage I got
11.90 on both green and red pairs
I will see what I can find on the thread you sent me next. I may be looking for threads on how to replace the stator before I am done.
August 28, 2010, 01:20:23 PM »
Quote from: WednesdaysChild on August 28, 2010, 01:18:24 PM
Yeah...those are battery voltage.
Let us know.
You might also check the wiring/connectors at the regulator.
A bad connection or burnt wires will give you problems.
WednesdaysChild
August 28, 2010, 02:08:29 PM »
On the yellow wires my reading were
25-38 volts AC
Appears my stator may be working properly. Perhaps I got a bum regulator, or my connections are bad.
August 28, 2010, 02:12:39 PM »
Quote from: WednesdaysChild on August 28, 2010, 02:08:29 PM
25-38 volts AC
Either way...
it's a lot less work/money than a stator.
WednesdaysChild
August 28, 2010, 02:23:56 PM »
I ran the same tests with my old regulator and got the same findings.
11.9 on red/green
and
25-38 AC on yellow
So it has either got to be both regulators are bad or I have a bad wire/connection.
The Regulator I bought was an ESR531 Honda Super Duty and supposed to be a match for my 07 M695.
The connections look good were they connect to the regulator, dirty outside but clean metal contacts inside.
August 28, 2010, 02:31:58 PM »
Quote from: WednesdaysChild on August 28, 2010, 02:23:56 PM
11.9 on red/green
and
25-38 AC on yellow
Don't know about the honda regulator. Where did that info come from?
Did you check all 3 pairs in all the combinations?
WednesdaysChild
August 28, 2010, 02:38:43 PM »
I did try all three yellow combinations, I did not reverse the + and - leads on the multimeter and do it 3 more times though. I figured with good readings thrice it was a positive indication.
This is where I found the regulator information and made my purchase
http://www.electrosport.com/street-bikes/ducati/695-monster-06-07.html
August 28, 2010, 02:40:27 PM »
Quote from: WednesdaysChild on August 28, 2010, 02:38:43 PM
Solid link and vendor...
Maybe just a bum regulator.
I'd contact electrosport
WednesdaysChild
August 28, 2010, 02:48:53 PM »
I have contacted them and given them my info and test readings and hope to get it replaced quickly. humorless, thank you for your responses. It makes it easier to diagnose/fix a new problem when one has a second opinion in the matter. This was my first post since moving from the "other" board and am happy to have a positive experience.
Scotzman
Now that's thinking with your
Reply #14 on:
August 28, 2010, 03:07:09 PM »
On my 08 695, had a similar issue a few months ago and turned out to be the stator. It took a few times going back to the shop for them to catch it because it was just under the limit on what it should've been-hopefully there's a cheaper problem than this. Good luck.
