Map needed for PCIII
Started by Duc Rider, September 03, 2010, 12:05:26 AM
Duc Rider
Hi All,
Anyone knows the place or links where contain tons of map for PCIII? Your advice will be highly appreciated. Thanks a lot
Try this link: http://tinyurl.com/2359x3x  ;D
Also the powercommander site has a pretty good set of baseline (different pipes, airbox & even high comp pistons) maps as well. You should be able to get close with those.
Duc Rider
Thank you very much!!
Is there any where else? For PC site itself, I have visited there but look like there is no map close to mine. But I will try again & again .. Thanks anyway ..  ;D
Markus
It'd be helpful if you posted your bike's year, model, and appropriate mods (air filter: type; airbox: open vs stock; exhaust: stock vs aftermarket slipons vs full system; and pistons: stock vs hi-comp). You may find more people who can help by giving you their custom maps if you post that crucial info.
That said, in my experience it's absolutely worth paying the couple of hundred bucks to have a custom map made on a dyno by a professional shop. However, if you do decide to wing it and make adjustments based on butt dyno feel, do so in small increments.
Good luck.
2000 M966Sie
2007 ST3s ABS
www.eastcoastducaticlub.com
Duc Rider
My bike is S4R (Y03) with Remus Exhaust Full system + K&N Air filter. Thanks in advance for your advice & support.
