February 06, 2025, 07:12:05 PM
Monster 696 ABS - What to do to handle low speed jerkiness?
Topic: Monster 696 ABS - What to do to handle low speed jerkiness? (Read 6692 times)
muffinman
September 04, 2010, 08:16:14 AM »
Hey everyone- just got my M696 ABS and am loving it.. but I can't get over how jerky the bike is in lower RPM's + 1st/2nd gears. I do 90% city/highway riding and plan on commuting to work on my bike but the touchy throttle and on/off acceleration is a PITA.
Based on my research and from searching the forums, my options seem to be:
1.) Get used to it / break-in bike; it'll get better
2.) 14T front sprocket
3.) Throttle Tamer
I can't imagine, based on the comments here, that break-in will make the jerkiness THAT much better & and I have an ABS bike so 14T sprocket swap WILL not work. Ducati's official stance is that the ABS sensor uses both wheel speed and RPM readings
That pretty much leaves me with; Option 3... anything I'm missing here? I'd like to consider all of my options before splurging.
Thanks
Re: Monster 696 ABS - What to do to handle low speed jerkiness?
September 04, 2010, 10:47:24 AM »
DP ECU
i went back to the 15t and now have teh DP ecu. albeit with the electron throttle cam.
bike is smooth and quick.
jim_0068
September 04, 2010, 03:12:12 PM »
why wouldn't a 14t front sprocket work? Isn't the speed sensor on the rear wheel?
Amlethae
ahm-leth-eye
If life is a stage, you'd better let me direct.
September 04, 2010, 04:06:56 PM »
I'm running just fine with ABS (1100s) and 14T sprocket, dealer installed. ABS works just fine and like it should.
I got my 696 (non-ABS), put the termis & DP ECU on it as well as 14T sprocket and found it did fine in 1st and 2nd gear, made a significant difference for what you're talking about. I also used a throttle tamer on the 696 for a bit but didn't like it so much... the bike doesn't have enough power for the tamer, you'll be twisting your wrist far too much and find it annoying.
muffinman
September 04, 2010, 04:32:55 PM »
Quote from: jim_0068 on September 04, 2010, 03:12:12 PM
http://www.ducati.ms/forums/showthread.php?p=906811
The official from Ducati North America:
Quote
Thank you for contacting Ducati North America.
The ABS system uses both speed and RPM in its computations, two things directly affected by changes made to the gearing ratio. The ECU that governs the ABS system is programmed to work with the stock gearing on the bike only.
We hope this provides you with the information you were after.
Regards,
Customer Service
10443 Bandley Drive
Cupertino, CA 95014
Phone: 408.253.0499
www.ducatiusa.com
The ABS *may* work but it's not something I'm going to risk... neither will I risk voiding the warranty should anything go wrong with the ABS.
muffinman
September 04, 2010, 04:34:52 PM »
Quote from: Amlethae on September 04, 2010, 04:06:56 PM
Thanks for the heads up about the throttle tamer-
Quote
DP ECU
I'll def. have to look into the ECU flash; need to find how much it'll cost me before deciding between this & throttle tamer
Thanks
jvax
in the land of the rising sun
September 07, 2010, 03:29:09 AM »
Good info on this thread
Thanks everyone for sharing
'08 R1200GS
'10 M796 ABS Black (Sold)
Amlethae
ahm-leth-eye
September 07, 2010, 11:51:28 AM »
Quote from: muffinman on September 04, 2010, 04:32:55 PM
I got a better (more-detailed) official word from Ducati North America contradicting that one... check it out!
http://ducatimonsterforum.org/index.php?topic=42310.0
Go put on the 14T sprocket NOW, it's even cheaper than the throttle tamer!
arai_speed
September 07, 2010, 12:51:42 PM »
Cool deal - wonder why they told the other guy he couldn't change it
14T FTW!
[moto]
muffinman
September 07, 2010, 01:06:03 PM »
Quote from: Amlethae on September 07, 2010, 11:51:28 AM
You, sir, make the beast with two backsing rock.
speedknot
If a Honda= rice burner, then what is a Ducati?
September 07, 2010, 04:09:51 PM »
I don't mean to hijack this post but I was wondering if changing the front sprocket on my 01 M750 would alleviate some of the 1st/2nd gear low speed jerkyness. I am having the same issue, but I know its just how the bike is from the factory. If I was to change the sprocket, which one would you gear heads recommend? Thanks in advance.
2001 Duc M750, Harley Forty-Eight, 1976 Honda CB400F-SS, 1975 CB360T
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
September 08, 2010, 02:58:44 AM »
Quote from: muffinman on September 07, 2010, 01:06:03 PM
Another satisfied DMFer
. Gotta love this place and the help it throws up
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
seevtsaab
05 M620
September 08, 2010, 07:34:27 AM »
I can not make the beast with two backsing believe an answer would come out that ABS would not work with different sprocket.
Engine RPMs? So you have to be on throttle for the brakes to work?
Sorry, but that guy needs to be
fired
promoted.
Traction Control, I'd believe, maybe. 696 have Traction Control?
To the OP, best thing is to try to ride another 696 and see if something different about yours
(could be fueling issue?).
otoh very few have been dissatisfied with lower gearing (smaller front or larger rear).
September 08, 2010, 07:48:17 AM »
TC was my original thought in all this as well. wonder if they are thinking they could easily put TC on the new ABS bikes?
