January 20, 2025, 05:41:32 AM *
News: Please Help
Author Topic: Idling Issues - 2004 S4r  (Read 1621 times)
cyrus buelton
aka JuddDDDdd
« on: June 07, 2008, 03:21:21 PM »
I have a 2004 S4r.
- full system
- PCIII (custom map dyno tune)
The bike idles around 750rpm. It stalls pretty frequently. If I give it some gas, the damn thing dies.
When I adjust the fast idle lever so the bike idles right at 1000rpm, it runs perfectly.
I know this isn't the solution, but it is a temporary fix until I can get it sorted out.
How do I increase the idle without botching up the tuning of the bike?
1999 M750 (joint ownership)
2004 S4r (mineeee)
Online Online
« Reply #1 on: June 07, 2008, 03:37:01 PM »
I have a 2004 S4r.
- full system
Take it to a mechanic.
Seriously...you had a dyno tune done...
but did you have a thorough injection set up done?
Synch...air bleeds...TPS....idle speed....
cyrus buelton
aka JuddDDDdd
« Reply #2 on: June 07, 2008, 03:42:31 PM »
Yeah, it had everything done.
2004 S4r (mineeee)
MonsterMan1036
« Reply #3 on: June 09, 2008, 11:03:04 AM »
The TPS needs to be reset and the fuel idle mixture needs to be leaned out. I just fixed this on my dads S4R, it's only like a 5 minute job. The thing is you need to have the Techno Research soft ware. Where are you located at in Ohio because I would be more than happy to help you out if you are close.
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
Capo
You Are What You Is
« Reply #4 on: June 10, 2008, 02:04:12 AM »
Which 'full system' do you have?
Capo de tuti capi
