Death of an I-Pod
Started by IZ, September 10, 2010, 08:07:23 PM
Black screen..push button on button and no response.  Pushed Menu & Play buttons smultaneously and the same.  Any ideas?
Kopfjager
Quote from: IZ on September 10, 2010, 08:07:23 PM
Check on their website for troubleshooting tips.
Quote from: kopfjäger on September 10, 2010, 08:09:38 PM
Yeah, have that pulled up right now.
Kopfjager
Make sure your iPod is fully charged and then toggle the Hold switch on and off
To reset your iPod:
   * 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
   * 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
     Tip:
         o If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
         o If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep
Retry
Retry your iPod with a different USB port on your computer, not a USB port on your keyboard or hub.
Restart
Restart your computer, and make sure that you have the latest software updates installed.
Note:
   * To update your Windows software, select Windows Update from the Tools menu of Internet Explorer.
   * To update your Mac OS software, select Software Update from the Apple menu.
Reinstall
   * To update and reinstall your iPod software, first download the latest version of iTunes.
   * Next, open the new version of iTunes and connect your iPod to your computer.
   * Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
   * If this does not resolve the issue, try completely uninstalling iTunes and then reinstalling the latest version of iTunes. For more information select from the following
Restore
   * Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
   * 1. Make sure you've reinstalled the latest version of iTunes.
   * 2. Open iTunes, and then connect your iPod to your computer.
   * 3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
   * 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
   * 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
         o Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
         o Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
         o Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
         o Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
     Note: For Mac users, A message will appear prompting you to enter an administrator's name and password.
   * 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
   * 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
   * 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
And if none of that works, there are places that repair them.
Kopfjager
Quote from: kopfjäger on September 10, 2010, 08:28:32 PM
Does that mean you fixed it?
No, I'm going to fully recharge it and then try.  Thanks for posting.
herm
i as going to suggest charging it.... ;D
Kopfjager
Quote from: IZ on September 10, 2010, 08:30:10 PM
If you answer back with it wasn't charged, go choke yourself.  :D
Fresh Pants
Bwooooooahhh
Braaaaaaaappp
Rameses
El Matador
Quote from: Rameses on September 10, 2010, 09:18:01 PM
PULL!!!
*Kapow*
Nice shot mate, you really showed that black-turtleneck-wearing-asshole
have you tried a hammer yet?
herm
Quote from: lethe on September 11, 2010, 02:07:29 AM
that was going to be my second suggestion if charging it does not work..
