Need quick starter help please!
Started by duc[k], September 12, 2010, 12:51:33 PM
duc[k]
Hello all,
I am new to the forum but have used the search function more than a few times. I am having problems with my bike, 2003 620 monster dark. I have to drive it after it rained yesterday and last night when I went to drive it home there was a lot of condensation all over the bike. Now when I tried to start it today everything cuts on, the fuel pump initializes and when I push the start button it just clicks and clicks and the motor won't turn over. I figure it's a starter issue, or maybe the solenoid, but not sure either way. Insight would be greatly appreciated as my car is broke right now and the bike is my only transportation.
The clicking is the solenoid most likely. The problem could be a bad connection that is showing up from the moisture or a low battery can cause the same symptoms.
Bones
not to scare you, but make sure the battery is charged, the starter solenoid connections are clean and you will be saving yourself a lot of future grief if you just make sure there is no water inside your gauge housing (do a search on these).
I'm a loner, Dottie...a rebel...
