S4rs upper clamp size
Started by toudg, September 13, 2010, 02:51:15 AM
toudg
I wanna order the upper clamp from speedymoto for my S4rs.  Do I need the 53mm version (superbike conversion one) ?  I'm kinda confused ... ???
Thanks for your time !
Bill in OKC
I recently measured my S4Rs for new triples - it was Ohlins Ø50-54 upper/lower
Rameses
#3
Depends.
Have you swapped out your forks for SBK forks or are you running stock forks?
If you have stock forks, no, that won't work.
eta:
If you have stock forks, this's the one you need.
http://www.speedymoto.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=03-0208BLK&Category_Code=MTC
toudg
Thanks a lot, I'm running the stock ones ! [thumbsup]
toudg
Are you guys running a side mount damper with this kit ??
