February 04, 2025, 08:10:35 PM
Please Help
CAM
DOAH -- Gas Cap screw in Tank! Am I Screwed (Literally)
Topic: DOAH -- Gas Cap screw in Tank! Am I Screwed (Literally) (Read 2662 times)
TitanMonsterS4R
September 18, 2010, 01:46:08 PM »
Ok, in all my excitement and haste this morning I fixed my new red/black gas cap but in the progress dropped one of the larger screws into the gas tank. To make matters even better, they're aluminum, so it them out with a magnet is out since the screw doesn't have a strong magnetic force. Tried fishing it out with a flexible claw and dumping the tank of gas an shaking the damn thing out. NOTHING!
Does anyone have a cost effective solution to get the screw out? More importantly is there a filter in my tank ensuring the screw will not screw up my Monster and will spend its lifetime rattling around in there.
Thanks for the help.
Meerkat
When I'm not playing Silver Power Ranger, I'm a
Re: DOAH -- Gas Cap screw in Tank! Am I Screwed (Literally)
September 18, 2010, 02:45:39 PM »
That'll teach you to mod your bike when you could've been hanging in Paw Paw with the cool kids!
Sorry can't help with the screws, I've got enough of my own on the loose.
'07 S2R1K
'09 Daytona 675
'03 620 Dark-Sold 03/26/2011
The Mad King Pepe'
September 18, 2010, 03:10:03 PM »
You're screwed dude! Those screws are so small they can make it through the gas filter and eventually into the engine where they either get stuck between the valves or end up lodged into the piston!
Probably the easiest way to get the screw out is to empty the tank, take it off the bike, and remove the metal cover at the bottom where filter and sensor are mounted.
tuanogus
September 18, 2010, 03:17:08 PM »
Quote from: ReginaDiCuori on September 18, 2010, 03:10:03 PM
Aluminum screws in the gas tank eventually turn into unicorns in your muffler. Kinda like butterflies; but different.
J5
I'm here to fix zee fridge
September 18, 2010, 03:34:56 PM »
is your bike fuel injected ?
if so then you can take the pump out of the bottom, you will find the screw easy enough
good time to replace the filter while you are at it
TitanMonsterS4R
September 18, 2010, 04:00:13 PM »
Quote from: J5 on September 18, 2010, 03:34:56 PM
Yes, it is fuel injected (08 Ducati Monster 695). Wonder if I can make a 6 hour ride with it in there. Really don't want to miss the trip I planned to Gettysburg.
Thanks for the advice about taking the pump out of the bottom> Guess I have an early morning project.
J5
September 18, 2010, 04:09:51 PM »
i wouldnt worry about it being in there, will be ok
Omnipotent Potentate
Personal Pretext
September 19, 2010, 11:44:41 AM »
Nope... it's done. The spark of it's young life has been snuffed out... Smothered in shite... done.
I'll give you $1 for it... and that's generous.
To assuage your anxiety have a look at the parts schematic. I know my bike, an injected 900 has a pick up screen filter before the pump. You probably have something similar. It's a wire mesh encased bit of fiber (not sure what sort of fiber) that the pump draws the fuel through, protecting the pump from anything like, say, a dropped bolt. Having never gutted a 695 tank I can't say you've got one for, 100%, sure though.
ducati culture
My freedom is worth my life and my soul..........
September 21, 2010, 07:09:15 AM »
Use a telespotic magnet and you should be fine ( maybe not!). You can drain the tank to make it a little easier.
Last Edit: September 21, 2010, 09:33:32 AM by ducati culture
Artful
I'm glad they make pills for my
September 21, 2010, 07:36:02 AM »
Quote from: ducati culture on September 21, 2010, 07:09:15 AM
Use a telespotic magnet and you should be fine. You can drain the tank to make it a little easier.
http://www.howmagnetswork.com/
Quote
It attracts ferrous objects like pieces of iron, steel, nickel and cobalt.
Aluminum /= Ferrous as the OP pointed out.
The Mad King Pepe'
September 21, 2010, 07:36:38 AM »
as he said:
Quote from: KneeSlider on September 18, 2010, 01:46:08 PM
they're aluminum, so [fishing] them out with a magnet is out since the screw doesn't have a strong magnetic force.
Get more
ducati culture
September 21, 2010, 09:32:50 AM »
ok.. so do you have any fresh bubble gum?
TitanMonsterS4R
September 21, 2010, 09:53:59 AM »
took the gas tank off and removed the electronics to get the bolt from the bottom. In addition to finding the screw I found an elf. Do I have to return him to the previous owner or can I keep him?
Meerkat
September 21, 2010, 10:07:00 AM »
Fry him like
! Keeps the fingers warm when you ride in the morning.
'07 S2R1K
'09 Daytona 675
zooom
Reply #14 on:
September 21, 2010, 10:11:51 AM »
Quote from: KneeSlider on September 21, 2010, 09:53:59 AM
depends on what kind he is....
2010 KTM 990 SM-T
