Lost 1st - 3rd and Neutral on the way home . . .
Started by INFIDEL, September 20, 2010, 07:55:41 PM
INFIDEL
Help save a child: http://www.firstgiving.com/318
Twitter: http://twitter.com/318FORKIDS
M900
If you're running the stock clutch slave cylinder, the seals probably failed.  Do you see any brake fluid underneath the clutch slave?
ryandalling
I bet tis the gear lever return spring... I know, not the technical description... but same thing happened on my 848.
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
ryandalling
Yup... thats what happened to me... except the spring bits broke gear bits... and well it was a hot mess.
INFIDEL
No I'm not stuck in a gear.  I can shift in and out of 4th and 5th.  There's just nothing else including neutral.
Quote from: INFIDEL on September 21, 2010, 07:49:24 PM
I would still check under the left side cover. You have to start somewhere.
Howley
I'd ride or drive back the way you came and see if they are on the road.
Sorry, someone had to say it.
Düb Lüv
Building, building, building
