Anyone want/need a Dell Poweredge 2400
Started by ducatiz, September 21, 2010, 10:17:02 AM
I have a Dell Poweredge 2400 server that I used to use, dual P3's, (I think) a gig of ram, and a Mylex hot swap raid array.  It has four 18.2 gig drives and the config for the drives is in hardware, so you can do 0 thru 5.  boot CD and 3.5 floppy too.
$50?
I'd need to wipe the drives first to get all my pr0n off but let me know if you're interested.
I believe the CPUs are 800mhz, not sure.  It has been a while, I was using it for httpd and mail only, and a few lists.  Not sure which Windows/Linux systems it is compatible with, you do your research.  I had Win2k running on it.
tocino
Obsolescence is worse than death. Seems PC values drop faster than those of Monsters!  ;)
MongoReturns
I have a Toshiba Satellite Pro that I use as a doorstop.  It was $2k, state of the art [in 1998].
2000Monster750Dark: cored pipes, stage2, 43t, f-18, dptach
2007 1098Red: home depot cooler guard, on sale cluch cover, on sale dp dark tall screen, ebay hugger, hand painted clutch spring caps
