Cheaper service recommendations
Started by Scotzman, September 24, 2010, 03:31:03 PM
Scotzman
Need to have my 15k service done and have been qouted $800 +/-. Is there cheaper in the San Diego/Riverside area or is this the nature of the beast?
The Bearded Duc
Depends on what you have already had done and what needs to be done. If you need a full service i.e. belts and vlaves then that sounds about right.
My 15k involved an oil change and some other things I needed tweeked so it ran me about $150. But I also had a full service done at 12k.
What have you had done so far?
2001 M750 - Sold
Scotzman
The only thing done recently is changing the spark plugs, fuel and air filter-basic stuff.  How much was your service at 12k? I assume about the same.
The Bearded Duc
Can't find the receipt and I don't remember the exact number but it was between 700 and 900. If you're in need of a full service this is what you should expect to get done...
http://ducatimonsterforum.org/index.php?topic=41250.msg737841#msg737841
2001 M750 - Sold
Scotzman
Ok. Atleast I can leave off pads- one more thing I can do.
I guess this is the nature of the beast. ;D ... [bang]
The Bearded Duc
Yep. It's really the labor that casts so much, from what i understand. Adjusting the valves and changing the belts and timing can be somewhat time consuming.
If there is a bunch you can do yourself it will definitely save you some money. I really don't know much about the valves so I prefer not to mess around with the engine components. And as long as someone is in there doing the valves it's just as easy for me to have them do the belts.
2001 M750 - Sold
Scotzman
2008 695
I'm the same way, but I'll still try it if the directions are good enough and I have the tools.
Veloce-Fino
Quote from: Scotzman on September 25, 2010, 10:00:59 AM
2008 695
Valve adjustment is not too complicated. The problem is that the shim kits are crazy expensive. ~$300+
Is this thing on?
Privateer
my 12k was like $600 even but this was a couple years ago with Stu/Flight.
My experience with cars/bikes tells me labor is usually 1/2 the bill unless you're doing something crazy with parts (fuel tank replaced, maybe).
Scotzman
I'm now going through the list of things done for the service and determining whether I can do it or have them. The list is pretty short-pads, filters, plugs... but even if these few things takes off an hour of labor, that's $90 right there.
sbrguy
the big thing is the labor, the time you have to take half the bike apart to get to the shims is annoying you pay someone else to do that work.  i know that people say the shims are "easy" to do, and technically it isn't rocket science checking and replacing shims.
the hard part is that it takes time to get to them and then put hte bike back together and such, and that when you pay someone to take 2-4 hours to do a complete service instead of you using your free time outside of work is sometimes worth the money, at least it was for me.
the choice is yours.
Scotzman
Just got bike back after having a streefighter as a loner, but service came out to be $654. Can complain when I was qouted $800. Just doing filters and pads helped out though.
