School me on HID's
Started by Monsterlover, September 29, 2010, 01:47:58 PM
The headlights on my Accord aren't that great, even with the bulb upgrade I did.
I ran across these:
Link
Link
Link
The car's black and any of these would look pretty cool, but I'm not gonna buy garbage.
What's the difference between HID - projector - xenon and all that stuff?
Don't true HID setups cost a lot more than these do?
These things are all over ebay for just about any vehicle made in the last 10 years.
Im interested, but wary.
fyi..... when working at delerships in the service dept..... we saw lots of fried headlight wiring because of people switching out headlights.
That was another thing I was wondering about
a) extra heat
b) current draw
Porsche Monkey
Quote from: bobspapa on September 29, 2010, 01:52:29 PM
[thumbsup]   can't believe Joel actually has something constructive and relative to add to the conversation and that I agree with him. Wtf?
I fried the headlight multi-stalk switch in my '08 Ford Falcon (yes 2000 and 8  :P) in an ultimately temporary attempt to improve the shite stock lighting.  All I did was fit 'em blue looking aftermarket bulbs... same wattage...  Worked great.  Big improvement.  Right up until I couldnt turn em on at all.  The Ford tech ripped em out and said polite words to me which really meant "dont try that again, Dick Head".
But as I'm a slow learner..... I'd like to know more about HIDs too....
[popcorn]
zooom
Quote from: ungeheuer on September 30, 2010, 06:11:06 AM
[popcorn]
same wattage maybe...but not the same resistance...hence why these headlight wiring harness or pigtails are frying when people do things like this...some people delay the inevitable with this process by packing the connector full of dielectric grease...but ulimately it will still cook...
on HID's and conversion...some of the various seemingly inexpensive kits out there have results that may be marginally better than stock, but that is because they are using all the energy of the bulb(which is more lumens, generally speaking, than your stock halogens) but is doing so without the benefit of the proper refraction...nowadays the manufacturers are very good at designing these heavily polyagonal reflector/refractors in the headlight to spread the beam in a very specific way....they heavily account for the spacing, not only of the bulb, but for the placement in the bulb of the filiment for to get the maximum effect...alot of the inserted HID kits that are just a bulb and ballast and relay with wiring, do not exactly account for this and you may not get the best effect...some cars might be more amenable to the modification or with headlight adjustment get closer to the objective, but unless you are doing the reflector to accompany the bulb, I think it is somewhat of a lost modification for your time...this is before even looking at which range of gas discharge rated bulb even comes into the picture...then things can get really funky when you think about 4000, 6000, 8000, or which suits your wants best and your driving conditions...
2010 KTM 990 SM-T
Porsche Monkey
Holy crap!
What do you think I should do to get more output?
zooom
Quote from: Monsterlover on September 30, 2010, 06:57:55 AM
Holy crap!
depends on the year/make/model as to what advice I would/could offer...
2010 KTM 990 SM-T
Quote from: Porsche Monkey on September 29, 2010, 04:58:56 PM
every so often a blind squirrel finds a nut..... I be that nut  8)
Quote from: zooom on September 30, 2010, 07:03:32 AM
2004 Accord EX-L v6/6spd
Just put a couple of 1.21 jigwatt bulbs in there and be happy. ;D
Staggerlee
Wire in a couple of relays to get full power to your headlights.  You'd be amazed at the voltage drop you'll get through the factory harness.
This will 'splain everything:
http://www.danielsternlighting.com/tech/relays/relays.html
Unless your headlights now are a projector beam style, I would not mess around with the drop-in HID kits.
zooom
Quote from: Monsterlover on September 30, 2010, 09:21:49 AM
and I assume you have already inspected and tried making sure the lenses are clear and done something like a headlight wet sanding and buffing restoration kind of thing right?...and put in just regular new bulbs, since the tungsten filiments do have a lifespan where as they burn do naturally get somewhat dimmer over time...
just checking on the obvious 1st...
2010 KTM 990 SM-T
The lenses are good. One is as clear as new, the other is starting to haze a little in one spot but it's not bad.
The bulbs are factory replacements I put in maybe four months ago.
