February 13, 2025, 09:36:57 AM *
Pages: 1 2 [3] 4   Go Down
Author Topic: Who can tell me what's wrong in this pic?  (Read 7451 times)
Rameses
*Your Mom* has a Hypermotard
« Reply #30 on: October 05, 2010, 01:45:35 PM »
You can try that after you break off the extractor. Wink
You *really* don't want to break off an extractor in that hole.
Yeah, I've been there before.
I think the last time I had that happen was about 15 years ago though.
Hopefully I won't get a reminder of how badly that sucks.
Rameses
« Reply #31 on: October 05, 2010, 01:46:49 PM »
So you're gonna mig  and retap the aluminum cases?  Huh?
I think not Keemosabe.
Why not?
Online Online
« Reply #32 on: October 05, 2010, 02:06:03 PM »
Why not?
You'll never burn out the impurities with a mig.
Welding cast aluminum is tricky for an expert with a tig because of the oil that soaks it way into the pores of the casting.
I don't know a pro that would even try it with mig...it's just the wrong process.
But don't listen to me...what would I know...I'm just a painter.
Rameses
« Reply #33 on: October 05, 2010, 02:33:14 PM »
So a TIG arc has a higher temperature than a MIG arc?
And I have access to a TIG, it's just not that convenient.
Online Online
« Reply #34 on: October 05, 2010, 02:41:54 PM »
Mig is not a penetration process. It's also DC. You need AC to weld aluminum castings.
To fill that hole you have to keep the puddle molten as it fills.
You'll need a lot of amps to do it. Don't ask me the number, but if you get stuck I have a book that has the info in it.
Rameses
« Reply #35 on: October 05, 2010, 02:59:18 PM »
I've never welded cast aluminum before. All of the aluminum I've welded over the years has been plate and angle, so that's new to me.
Hopefully it won't come down to that, but I'll remember that if it does and get in touch with you.
Thanks Nate.
Online Online
« Reply #36 on: October 05, 2010, 03:04:00 PM »
Thanks Nate.
Just like plate and angle, that casting is a huge heat sink...and probably thicker than what you've welded in the past.
I watched a guy welding a large 1/2" plate weldment at 400 amps. The filler rod disappeared like spaghetti into Kent. Wink Grin
Rameses
« Reply #37 on: October 05, 2010, 03:23:41 PM »
 laughingdp laughingdp laughingdp
Bigbore4
« Reply #38 on: October 05, 2010, 05:45:11 PM »
<Snipped>
No TIG here, just MIG.
Regardless, how would you weld a stud to the remaining piece if it's broken inside the case?
If you are still fighting it, screw the stud.  Get a good supply of 3/8 or 10 mm nuts.  Center the nut over the broken stud, protect the piston, rings EVERYTHING and center the MIG gun over the nut.  Weld the nut to the broken stud.  I have a good MIG, not sure if a flux core rig would work.
Start working it while it's still hot, easy back and forth.  I twisted the weld off 6 or 7 times, but the weld bead kept building higher and higher, finally got enough material standing proud to get a really decent weld on it.  Once we had a good hold the stud freed up and backed out.  No re-threading no aluminum welding no nothing. Just some new and improved aftermarket studs.
It was the kids bike, I was the technical lead.  I have no idea what kind of studs he used, he did the disassembly and reassembly, I just saved the case from certain disaster.
Dave
96 M900         05 FJR         86 SRX6
And a brand new Super Tenere coming in no one knows
The best kind of whore is a
« Reply #39 on: October 06, 2010, 04:21:34 AM »
Here we go.  That didn't take as long to upload as I thought it would.
Effing Broken Stud
With this setup it only took about 7 hours of drilling to get deep enough to use an extractor.   Roll Eyes
I can't decide if I should be ashamed to have witnessed this or impressed at your ingenuity laughingdp
I'll go with the latter waytogo
nice Cool
Jobu
« Reply #40 on: October 06, 2010, 10:53:49 PM »
when is it set to catch fire?
 laughingdp
About five minutes after I get the confirmation that my insurance has been upgraded to full coverage.
 drink More like beer, especially this summer.  And don't you have something to go paint?  Tongue
Well, tried heat, hitting with a punch and hammer, and using a couple different extractors with and without the impact driver.  Stud isn't budging.  Why the make the beast with two backs did Ducati use stainless steel studs?
Anyway, I'm just gonna drill through it.  Better than halfway there as it is.  Hopefully then I can get the rest out, without f'ing up the threads too bad.
Thanks for the suggestions.
« Reply #41 on: October 07, 2010, 03:53:49 AM »
If you can, try to get a left-hand drill bit.
Sometimes those will work at spinning the stud out as they drill.
Jobu
« Reply #42 on: October 07, 2010, 04:16:31 AM »
Thanks, I know that, but couldn't find any.  One more tool place I need to go to look for some.
That also brings up another question:
Does anyone know how deep the stud hole is drilled in the case?  (How much space do I have before I start drilling the soft case once I'm through the stud?)  I have a reference by looking at the new studs compared to the broken one, but I'd like an estimate of the hole depth.
« Reply #43 on: October 07, 2010, 04:21:29 AM »
http://www.mcmaster.com/#left-hand-drill-bits/=965prm
Dunno how deep the holes are.
Online Online
« Reply #44 on: October 07, 2010, 04:23:47 AM »
Standard practice is to have a shoulder on the stud so it doesn't reach to the bottom of the hole yet can still be tightened.
From the pics it looks like that is the case. As hard as the stud is drilling you should know when you reach the end.
Another possibility is the hole is open to the crankcase and the threads are sealed, in which case it's more an issue of getting chips in the cases.
Pages: 1 2 [3] 4   Go Up
