February 14, 2025, 08:34:27 AM
Ducati Diavel [HFL]
16
17
18
19
20
Topic: Ducati Diavel [HFL] (Read 73982 times)
IdZer0
BE
Re: Ducati Diavel [HFL]
Reply #240 on:
November 01, 2010, 02:45:04 AM »
some new pics and boy does it look
ugly
heavy:
http://www.wired.com/autopia/2010/11/ducati-builds-a-devil-of-a-v-max/
replaced by 2011 848 EVO
toudg
Reply #241 on:
November 01, 2010, 04:18:50 AM »
HEAVY FAIL.
http://www.ducatinewstoday.com/2010/11/first-ducati-diavel-photos-from-milan/#more-8308
or here
http://www.italiabikecenter.com/?page_id=44&album=2&gallery=7
Last Edit: November 01, 2010, 04:22:47 AM by toudg
Omnipotent Potentate
Personal Pretext
Reply #242 on:
November 01, 2010, 05:33:10 AM »
Quote from: IdZer0 on November 01, 2010, 02:45:04 AM
So that Autopia link (above) has a link to a specs PDF
http://www.wired.com/images_blogs/autopia/2010/11/MY11_Diavel_Tech_Spec_EN_IT_v05.pdf
There's two versions listed. Regular and Carbon. The only differences I can spot in a quick skim are different wheels, 14 spoke for regualr and 9 for the Carbon and the the difference in the claimed dry weights at
463
and
456
pounds respectively.
Looks like both are getting all the electro whiz-bangery:
"Tank mounted instrumentation with TFT colour display:
Gear selected, air temp, battery voltage, trips 1 & 2, fuel
reserve trip, average and actual fuel consumption and speed,
trip time, scheduled maintenance. Full status and/or
management of
Riding Modes, DTC, RbW and ABS
Another thing to note is that they are listed as two seaters... must be able to pull off the rear cowl, and I remember seeing some spy shots that appeared to have fold out passenger pegs. *Edit - they pegs are pretty easy to see if you look at the photos from Milan
Last Edit: November 01, 2010, 06:21:06 AM by yuu
Reply #243 on:
November 01, 2010, 05:53:25 AM »
ugly
heavy:
hmmmm
based on the seat/handlebar position, looks like they jazzed up the ST quite a bit
loves ze desmodromics.
Reply #244 on:
November 01, 2010, 06:13:58 AM »
needs a dry clutch conversion kit in the parts catalog so we can one-up the cruiser dudes with more shiny spinning parts.
doesn't look "heavy" to me for what it is - looks like a mid-400 to 500 lb ride. i feel like you guys forget that the 748 series weighed a TON in biposto trim. the ST series weighed a sh!t-ton (metric unit).
muskrat
Reply #245 on:
November 01, 2010, 06:40:19 AM »
It's a cruiser, an ugly one at that IMO but 500lbs is more than reasonable in weight. He'll I'd hate to tell all of you what my Harley weighs.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Reply #246 on:
November 01, 2010, 06:42:53 AM »
960+, yes?
Personal Pretext
Reply #247 on:
November 01, 2010, 07:03:58 AM »
The 'light weight' XR1200 tics in at 573 in running order, an Electa is 940+ and a night rod is 676 in running order...
Triple J
Reply #248 on:
November 01, 2010, 07:09:11 AM »
That thing is seriously ugly. The front end intakes and radiator cover literally look like they were just bolted on after thoughts. There is no flow to that bike whatsoever. The "trellis" frame is a joke...nothing is symmetric or even. The angle of the tail doesn't seem to flow with the rest of the bike. The cowl around the headlight is just lame looking.
Cruiser or not, I'd admit it if it was a good looking bike. It is not. The RSD version was very cool looking, but geez it had a lot of mods looking at this!
Here's another view. It defintely looks better in black above.
...and people thought Terblanche's designs were ugly.
Last Edit: November 01, 2010, 07:10:59 AM by Triple J
duccarlos
Reply #249 on:
November 01, 2010, 07:23:34 AM »
I have to say it is quite ugly. I think the next bike will be an 1100 if it comes with ABS and new engine.
Gimpy
Not quite a
Reply #250 on:
November 01, 2010, 07:35:12 AM »
There are a few things on this bike I do like; The rake of the front, and the tail. If I were to buy it, I would definitely have to have a plan to mod away the air scoops and the mufflers. Maybe see some straight pipes off the back and the tank panels from the newer monsters. If it has a squishy suspension it would be perfect for my slab commute.
2001 M900 Dark
duccarlos
Reply #251 on:
November 01, 2010, 08:15:17 AM »
Pipes would be the first thing to go
muskrat
Reply #252 on:
November 01, 2010, 08:17:43 AM »
pipes, air scoop and headlight (whatever the hell that is) plastic piece all GONE GONE GONE.....
2015 MTS 1200
09 Electra Glide
Mojo S2R
. Dark Mojo .
Reply #253 on:
November 01, 2010, 08:27:26 AM »
I still like it. In the black, just not in the red. Those silver scoops and headlight look out of place. Maybe if they were black or maybe red, even though I think that may be too much red. Can't wait to see how people mod it once they get their hands on it.
My bike so far...
My desktop/wallpaper
CCMHA Map
Central Cal Monsters
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
Reply #254 on:
November 01, 2010, 08:42:53 AM »
Quote from: Mojo S2R on November 01, 2010, 08:27:26 AM
It's got potential. Similar to the monsters it needs a shit-ton (metric unit
) of modifications to make it look cool.
Is this thing on?
16
17
18
19
20
