LED turn signal resistors
Started by ungeheuer, October 07, 2010, 05:05:36 AM
Is the flasher relay still built in to the gauges?
If so, wouldn't a bunch of re-wiring be necessary to eliminate that one?
And therefore not as simple as replacing the flasher on an older model. Probably not enough room in the gauge to swap to the LED unit as it's about 20 by 40mm.
Meh... why complicate things with replacement flasher modules?  Cheap, simple little resistors work well and are easy enough to find a home for.
My point was merely that they do get surprisingly hot when under load and so its probably prudent to mount them accordingly  :)
