August 14, 2024, 12:21:27 PM
NMMR
ducducgooseme
Independent Service? The Desert Desmo Thread
8
9
10
11
16
Topic: Independent Service? The Desert Desmo Thread (Read 67853 times)
DonJuanDucati
Re: Independent Service? The Desert Desmo Thread
Reply #120 on:
September 10, 2011, 01:23:54 PM »
Same hose split, this time instead of at the nipple of the pump outlet, it split at the fuel filter nipple. Just cut it, got rid of the clamp, and put on a new worm gear clamp. Hopefully the hose will last long enough for me to ride it over. I'm thinking Monday evening (6pm ish) may be a good time for me to bring it over.
gfitzgi
Reply #121 on:
October 02, 2011, 05:25:39 AM »
Hey Stu or Scott,
I have a question for the maybe either of you when you have time.
I have always had false neutrals between every gear since I got my '03 620. I know it is a common problem with a fair amount of Ducs, but they seem to be getting "wider". Especially the one from 4th to 5th. I have always wanted to go to the 6 speed any way, I am getting quickly to my 12k service and am wondering two things.
Can I adjust/shim the tranny I have to get the neutrals "smaller"?
Do you know what years 6 speed transmissions our fit my machine?
No huge rush, just always been a topic of curiosity for me, and with the gaps seeming easier to hit as the miles build I am hoping I am not going to "need" a new transmission too soon.
I have never done any transmission work before so know next to nothing about them. I learn fast however, and am not afraid to tear anything apart.
Thanks for any help/suggestions.
Moderator
Reply #122 on:
October 02, 2011, 02:43:47 PM »
Hey Scott,
There's a spring under the alternator cover which does get weak over time which could cause the issue you're having w/false neutrals. The spring costs $5, but it's 1.2 hours to R&R. While 'in there' we can set your shift mechanism to it's factory setting (if it's moved as they sometimes do) which will also help w/shifting...
As far as the 6-speed goes, it would be cheaper to buy a later model 620 engine (I have 1 BTW) which already has the 6-speed trans and the APTC slipper-clutch in it.
PM me and we can discuss motor swaps and services...
Zaster
Only Pam can touch my
2007 S4RS (sold) , 2008 1098S (sold), 2013 1199R,
Reply #123 on:
November 03, 2011, 07:30:17 PM »
Thank you for the chain and sprocket service with lifetime warranty to boot
Cloner
Nah...I ain't no stinkin'
....because a mind is a terrible thing......
Reply #124 on:
November 03, 2011, 07:47:34 PM »
Use them well, Karl. I'm glad we could help you out!
For those not "in the know", Desert Desmo LLC is now an authorized Supersprox dealer. If we supply and install a kit consisting of a Supersprox front sprocket, Supersprox rear sprocket, and quality RK or Isis chain, we can offer them with a LIFETIME warranty! (nontransferable, of course, but still.......) The next chain and sprockets you buy could literally be your last. Get 'em while they're hot!!!
Never appeal to a man's "better nature." He may not have one. Invoking his self-interest gives you more leverage. R.A. Heinlein
'64 Ducati Monza 250
'00 Aprilia RSV Mille
'03 Ducati 800 SS (race bike)
'04 KTM 450 EXC
DucMouse the Mighty
At least the smartess part of my body is my
Reply #125 on:
November 14, 2011, 09:56:05 AM »
I would like to thank you guys for doing the swing arm for me
spankin™
JJ
RED DEVIL PROPELLED WITH LOUD DESMO~~FIRE~~
Reply #126 on:
November 14, 2011, 01:06:50 PM »
Quote from: DucMouse on November 14, 2011, 09:56:05 AM
Splendid! When we fly???
Last Edit: November 14, 2011, 01:09:32 PM by JJ
Ride forever...
DonJuanDucati
Reply #127 on:
March 27, 2012, 03:00:24 PM »
Hey, just changed my oil and a found some small magnetic shavings on my plug. Very small, mostly dust sized. I didn't find any thing bigger in my filter and I didn't check the prefilter. From what I read this is just normal transmission wear?
Moderator
Reply #128 on:
March 27, 2012, 09:10:54 PM »
Quote from: DonJuanDucati on March 27, 2012, 03:00:24 PM
Generally, a small to moderate amount of metallic 'dust' is normal. When you get an excessive amount, or larger bits... Then you have issues.
I wouldn't be concerned unless we're talking about a dust-ball larger than a dime.
DonJuanDucati
Reply #129 on:
March 28, 2012, 03:13:59 AM »
Nah, nowhere near that much.
Cloner
Reply #130 on:
March 28, 2012, 06:51:10 AM »
You're good to go, then. Don't put 'em back in there, though.
'04 KTM 450 EXC
future rs
Reply #131 on:
March 28, 2012, 01:02:39 PM »
how much is the general time and cost of the valve check/adjustment? another 200 miles and ill be needing to get it done.
Moderator
Reply #132 on:
March 28, 2012, 07:33:17 PM »
Quote from: future rs on March 28, 2012, 01:02:39 PM
Depends on the bike & motor. Feel free to PM me here & we can discuss.
Stuart
Cloner
Reply #133 on:
March 29, 2012, 05:30:05 AM »
How many miles on your 848 Beau? I should remember, but I don't.
Anyway, it depends on whether you want a full service or just the valve check/adjustment.
The full service is 6 hours for minor service (7500 mi) and 8 hours for major (15000 mi) on your four valver. We'll shave 30 minutes if you'll remove the side fairings for the minor and ALL the fairings (including the headlight fairing) for the major. Labor is $76 per hour (including shop supplies) and parts are extra, though we pass along whatever discount we can, and we get a good deal on lots of things.
For either service you should expect the cost of oil, filter, and drain plug gasket at a minimum. If it's a major service, or it's been more than two years since they were replaced, you should expect to replace the timing belts. We can get a set of those at such a good price that I'm not legally allowed to publish it on this or any forum.....but suffice it to say we get excellent pricing from California Cycleworks on their ExactFit belts. For a major you'll also need new coolant and a prescreen gasket, and spark plugs are a good idea. We check and change several other things, but their cost is included in the price of the service.
If you JUST want the valves checked, and wish to do the rest for yourself, we'll check the valves for 4 hours labor if you remove the fairings. That four hours includes the cost of installing new belts (but not the cost of the belts themselves) if you want them changed, as we have to remove them to check the valves, anyway.
There are several other things we can do in addition to the standard service at your request. The most common is a fork oil change that requires 1 hour additional labor if you want that done.
Holler when you're ready!
'04 KTM 450 EXC
future rs
Reply #134 on:
March 29, 2012, 07:38:56 AM »
its a 4 valver. im currently at 7300 miles.
ill be doing the belt/valves/and just a general check over on the bike (chain etc.)
i may concider the fork oil as well.
Oil was just changed 400 miles ago along with the clutch.
8
9
10
11
16
