Time with Duc mechanic-what needs to be done for a good S2R1000 tune?
Started by WetDuc, October 10, 2010, 07:03:42 AM
WetDuc
I've got to know the local mechanic at the dealership and they have agreed to take me back and explain/show and help me do a full tune up and anything else I want in the shop afterhours.  Should be fun, nice guys, my new bike.
The shop has no dyno.  Basically, my bike is 2007 S2R1000, 2000 miles, DP ECU, Termi carbon cans and the "will be installed" Marving midpipe.
It hasn't had anything but oil changes and hydraulic fluid changes since coming into existence.
My list right now included:
-belt change
-valve check
-trim setting
-TPS reset
-cylinder compression check
-fork oil change
-fork suspension setting check
-rear shock/dogbone setting check
-throttle body sync
What other things should I address?  Should I not do some of these things or spend more effort in another area?  Especially pertaining to anything I can do while the bike is hooked up to the DDS.  I appreciate any input from you guys.
greenmonster
Throttlesync.
Major nuts & bolts.
Chain & sprockets.
Brakepads wear.
All above seems relevant to me.
M900 -97
MTS 1100s  -07
WetDuc
I can do a lot of the checks myself, but the throttle sync was a good one, I forgot about that.
booger
degreeing the cams on top of everything else could potentially yield great benefit, it's not difficult and no major disassembly required
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
WetDuc
evoasis
Check the pneumatic fluid, I know I do every 200 miles but I'm a little anal like that.
I guess there are good and bad mods; you'll find the good ones here ;)
WetDuc
Speeddog, 2000 miles is correct, it's basically just been broken in.  Most of these checks/adjustments I want to do because I do not know the bike's short history and I want to make sure all is well as I go into riding this bike for what hopefully will be a long time.
If there are things on my list that any of you may feel are completely unnecessary and would just be a lot of work done too early on this bike, please let me know, it will save me money.
evoasis, when I got the bike it had a really funky fluid color in the clutch master, so I changed all the clutch/brake fluids since I got it and will keep up on that.  I'm mainly trying to do stuff with the mechanic that I can't or probably shouldn't attempt on my own yet.  I'm no mechanical master, but I like to think I can get more done that the average guy.
Thanks
I'd do them in this order:
-belt change
-valve check
-cylinder compression check (Just for fun, to see if there's any difference after valve clearance setting)
-TPS reset
-throttle body sync
-trim setting
-fork oil change
corey
have him check the cush drives on the back of the sprocket carrier. a couple (and i do mean very few) folks have had issues... including a ruined eccentric hub. don't get scared, probably fine... just make sure you take a look there.
WetDuc
I'll definitely check that out.  Can you briefly describe what kind of things I could look for at the cush drive to identify any signs of problems?
corey
Quote from: iamhybris on October 15, 2010, 05:17:46 AM
Sure can. Check this thread out: http://www.ducatimonsterforum.org/index.php?topic=34425.0
Like i said, it's pretty scary business. Don't be too alarmed, I doubt you'd see this on a bike with such low mileage.
Just something to keep an eye on.
WetDuc
The midpipes are in the mail!  As soon as they get here, I'm going to get the tune.
If there's any other nuggets anyone has a few seconds to add, I'd still greatly appreciate the input.
Mr Earl
Quote from: evoasis on October 14, 2010, 03:10:27 AM
Um, isn't that air?
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
WetDuc
