December 18, 2024, 09:20:43 AM
Serious Safety Issue on a 2009 Monster 696
5
9
Topic: Serious Safety Issue on a 2009 Monster 696 (Read 29290 times)
2003 M1000s
Re: Serious Safety Issue on a 2009 Monster 696 NOW with photo
Reply #30 on:
October 12, 2010, 12:33:12 PM »
My bike (2003 M1000) uses a different system, so I am just learning how this one works. What is supposed to keep the sprocket located on the shaft? I understand the plate in the groove, but should the shoulder of the sprocket also be close to the engine case or is there enough clearance to move like the OP's photos?
homepage
http://sites.google.com/site/mittelstadtc/
Turf
Awesome > Logic
Reply #31 on:
October 12, 2010, 12:40:30 PM »
there is enough room to move like on the OP's photo
it's the plate that sits in the groove and is offset so that it can't move because of the splines and is held in place by two bolts on the countershaft
It's painfully simple and could be improved, theres just very little reason to.
Last Edit: October 12, 2010, 12:42:44 PM by Paper5tr3et7
Spidey
Crashin' mofo
Reply #32 on:
October 12, 2010, 12:49:09 PM »
Quote from: mitt on October 12, 2010, 12:33:12 PM
This looks like the same system as they had on the 620 and the "smaller" monsters. The sprocket is kept from moving off the end of the shaft by the retaining plate. The retaining plate *should* remain in the groove while the sprocket floats on the shaft. The retaining plates' splines should NOT line up with the splines on the output shaft, so that retaining just rests securely in the the groove. I suppose if you overtightened those retaining bolts, it could bent or warp the retaining plate and it could slide itself and the sprocket inward toward the engine. To answer the other part of your question, there is nothing that keeps the sprocket from moving inward toward the engine except chain tension and wheel alignment. There's some freeplay in the system, but I haven't seen it be a problem before (not that I've seen a bizillion of 'em or anything).
I'm betting this is human error of some sort--either in assembly(?), from the prior owner or from the shop.
Re getting a lawyer, you're not at that point yet.
mikesmithmjs
Reply #33 on:
October 12, 2010, 01:01:35 PM »
I still think this is a serious issue because even if there was human error, there has to be some sort of mechanical way to prevent this kind of mishap. we've put monkeys into space in 1949 and yet we can't prevent a chain from causing significant damage and possibly a serious accident.
i've mentioned that this is out of warranty. is there any incentive for ducati to repair this on their quarter?
Has anyone had them "have your back?"
i'm really bummed about this because to repair is ~50% of the resale value of the bike.
Last Edit: October 12, 2010, 01:20:04 PM by mikesmithmjs
Turf
Awesome > Logic
Reply #34 on:
October 12, 2010, 01:07:34 PM »
Quote from: mikesmithmjs on October 12, 2010, 01:01:35 PM
It seems like something ducati would goodwill, I used to be a service guy at a duc shop, ask nicely and be cool and the service guys will do what they can for you. Ducati Goodwills a fair amount of stuff that is questionable, you stand a pretty good chance of getting it.
Spidey
Crashin' mofo
Reply #35 on:
October 12, 2010, 01:08:18 PM »
A lot of it will depend on your dealer. Sometimes Ducati will take of something if it's out of warranty as a goodwill gesture. I have not idea when or why they do it, but it almost always requires the shop to be behind you.
Is the 'dealer' you mentioned a Ducati dealer? I assume you bought the bike at the same place you recently had it servived. And have you talked with the manager there?
DucatiSTi
Reply #36 on:
October 12, 2010, 01:11:25 PM »
First off, that sucks
In pic #1, it shows that the retaining plate is not holding on to anything except the sprocket
IIRC, when I changed my sprocket on my 696, the toothed retaining plate slides onto the toothed shaft and positions the sprocket by means of the groove on the shaft - I think the retainer rotates in the groove, lining up with the screw holes in the sprocket thereby locking the sprocket in the correct position
If the sprocket was never touched, then the retaining plate was never installed correctly at the factory - time to call Ducati
Good luck
2009 696 Monster - Arrow Carbon slip-ons, Bitubo steering damper, DP oil cooler, DP Touring Seat, Rizoma tail chop, Rizoma Zero 11's, Stebel Nautilus horn, Ducati Euro shroud, Speedymoto sliders (axles and frame)
Ddan
Some of my best friends are whores
Reply #37 on:
October 12, 2010, 01:12:56 PM »
It would take some serious work to install that retainer plate wrong. Both my 900's have the same system and I've never had a problem. The only way you could get the grooves in the plate to line up with the splines would be to have a lot of slop in either the sprocket or the shaft. I don't think the failure is in the retainer, you've got something else going on. Where did you host the pics? I'd like to see the third one blown up.
1992 900 SS,
currently a pile of parts.
Now running
flogged successfully
NHMS 12 customized. Twice. T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
mikesmithmjs
Reply #38 on:
October 12, 2010, 01:15:36 PM »
Dan,
photos are on flickr
user name = mikesmithmjs
mike
Reply #39 on:
October 12, 2010, 01:16:01 PM »
56+K on mine, original retainer.
WetDuc
AKA iamhybris
Reply #40 on:
October 12, 2010, 01:19:44 PM »
How can your duc be out of warranty if it is an '09?
mikesmithmjs
Reply #41 on:
October 12, 2010, 01:23:27 PM »
Quote from: iamhybris on October 12, 2010, 01:19:44 PM
it originally was purchased in summer of 08. first owner put 182 miles on it, then traded it in for a BMW.
battlecry
On a silver black phantom bike...
Reply #42 on:
October 12, 2010, 01:31:53 PM »
That guy did not like chains.
mikesmithmjs
Reply #43 on:
October 12, 2010, 01:33:44 PM »
Quote from: battlecry on October 12, 2010, 01:31:53 PM
i'm starting not to as well
WetDuc
AKA iamhybris
Reply #44 on:
October 12, 2010, 01:42:14 PM »
I see.
I always hated that little plate, although you are the first person I've seen have it fail. To me it would have to be installer error, some kind of forcing or incorrect part.
JB weld the swingarm chainsawed chunk maybe?
5
9
