Oberon Clutch Slave Cylinder
Started by duk too, October 15, 2010, 01:15:23 PM
duk too
Quick delivery from Motowheels.
Install went okay. A bit of a messy job. Trying to catch fluid and keep it in container, blah, blah blah. Had to bleed the system at least 10 times to get a good clutch. :P
The Oberon piece is exquisite looking ;D, but clutch pull is not reduced as much as I dreamed/wanted it to be. [thumbsdown]
They say around 30% less pull, I think maybe 15 to 20% less pull. Its hard to gauge, but it is a little better and anything is better than stock. IMO
sfarchie
That sounds about right. A friend also has the Oberon, but I went with the NCR slave cylinder. When we compared the pull, the NCR was significantly smoother and easier, but you also pay nearly twice as much.
http://www.desmoworks.com/index.php?main_page=product_info&cPath=401_418&products_id=501
Ray
SFaRChie
