Some modifications I've been planning for a while....
Started by goldFiSh, October 16, 2010, 05:18:29 PM
goldFiSh
So I've been collecting bits for a while. Yesterday it all got put together, following similar mod routes by Suzy and Dez.
Big thanks to Dockstrada for doing most of the work, and to Mattyvas for his ever helpful assistance as well...
mods done:
- SBK forks - from a 999.
- new rotor spacers, front fender, top triple and the like to suit (axle was already drilled!)
- Apex riser clipons
- new master cylinders off S2R1000
- new Rizoma reservoirs
- new ASV shortly bling levers
- lowered the gauges and headlight about 40mm
- headlight ring linished back to get rid of the chrome look
- replaced brake pads and fluids whilst we were there
- preliminary suspension setup
still to do:
- a bit of clean up on the cable routing
- replace the brake light switch - difference switch setup on the coffins..
- when I'm happy with the setup finish the top triple (perhaps mill and fill the handlebar locations)
- fit and tune the power commander
- 80% certain on the tail chop
Matty has more pics, which no doubt he will add in time.
it's a new bike! Most more weight over the front, and the clip ons have me tucking the ebows in. Clipons are above the triple, and to do so, I've lost 5mm of fork length, so turn in is faster - we'll see how that goes with more spirited riding... I've set the clip ons to the lowest position to see how bad it might be on the wrists, and so far so good... I'll reserve judgement until I do a 600km day though!
Some pics for you all..
Two dogs
suzyj
goldFiSh
Thanks!
It does feel really good too - it's completely transformed the feel of the bike. I've got room to move with the riser clip ons, so I may bring them back up 20mm or so. But it looks heaps better low, just gotta see what my lower back and wrists have too say about it.
I've only had some relative short and docile trips on the bike so far. I'll report back more once I've had a day on it through twisties..
Six95
Nice one Nick.
The master cylinder swap over - was that straight forward?
The sound of Ducati - A symphony of internal combustion
goldFiSh
mostly.... here's the differences
- levers, you need the small pivot for anything other than coffins
- switches, they're different on the coffin, so make sure you've got that covered (which I did not!)
You'll note from the pics that the lines' ends and length make the lines stick up infront of the new lowered cluster. not a big deal, and with a bit more time to tweak, maybe I'll find another way to do it... if not, the only way to fix is to get new lines with different ends that angle the lines differently... I'm not sure this would be an issue with std height gauges..
Dannog
Betty
Well done Goldie. How do you find the forks?
Having recently been playing around with some different ergos myself ... I didn't find that much trouble with the wrist and back - I have struggled with the clutch action though (assuming that is not related). If you use the bike as a commuter or travel at constant slow speeds ... I can foresee a few problems. If not, then you shouldn't have too many problems for 'spirited' riding - speed helps to support your upper body and cornering adds variety to keep your bit moving.
For 600+ days you would probably be feeling it anyway [cheeky]
Enjoy.
goldFiSh
Forks are great..... Well, heavier springs are great and the ability to set thrum up is great. The bike is due for a service soon, where I will get the fork old replaced (we ran out of time / forgot to do it) and I need to really ride it other than around the city to really check it out.
Same goes for the ergonomics.... I do have the option to take the clipons up 20mm if I want, and I agree with your comments on the spirited riding and that the clipons will have a positive effect in that area.
monstermick58
Nick, thought you might have given us an update.
Did you make any adjustments to the front end?
What about the clipons, do they feel ok?
I heard you talking about some adjustments that you were going to make when we got back from the run to Jenolan Caves.
Keep us updated on your developments
                                          Mmick
goldFiSh
Thanks for the prompting mmick....
Yep, there a couple of things to do. Firstly I need to reduce the amount of sweep on the clipons. After about 4 hours of riding, the throttle wrist was very sore - not from putting weight on them but due to the angle of my wrist.
The second thing I need to do is soften things up a bit. During the ride I felt the front end skating during bumpy corners and I lost a fair bit of confidence in my front end.
In all reality, I need to get my suspension properly sorted. A parting from getting the settings right, my gut feel is that the rear spring needs to be heavier and we never swapped the fork out out when we did the front end, so that's where I will start..
Once I have the cash, I'll simply take it to one of the suspension guys for setting up.. What's your experiences people in Sydney? I know people who have used Zeno, Tecknic and Terry Hay. Are there any others?
Roaduser
Quote from: goldFiSh on October 17, 2010, 02:39:46 PM
can u please tell me what is different with the switches and what i need to have it covered? im looking at a set of the same masters and would love to know what im in for while i await the post man.
Cheers Clint.
Roaduser
Another question, did u need to add rotor spacers to do the sbk conversion or was there another reason for them. reason i ask is in suzyj's thread they say there was no need for spacers. u used 999 and they 998 but i thought they were the same except for the tini depending on the version.
"I also swapped to 320mm rotors and four pot calipers, but my standard 695 brakes also fit with no hassles.  Indeed everything at the wheel end just works - no spacers or mucking about.  Even the fender bolts up perfectly."
http://ducatimonsterforum.org/index.php?topic=41414.msg740226#msg740226
it appears u already had the 320 rotors and 4 spot callipers as do i.
Thanx for your help here. saves me a lot in the trial fitting stages if i know what im looking for.
Cheers Clint
goldFiSh
Hi Clint,
Regarding the switches, the issue is the brake light switch, and specifically the way it mounts. Basically, the coffin master one will not work. Hopefully get one with your new master cylinder, or you can also use a banjo bolt pressure switch (a brake light switch that is built into the brake lines banjo bolt - can be had for about $20 USD as opposed to $80 for a ducati switch from frasers)
You will definately need the spacers with the stock 320 rotors and gold line calipers and 999 forks - I got mine from "somedude" on the forum in the states, who is a machinist and made some sets up. They cost a bit to get here, but worth it. Dannog also told me (when (I bought the forks from him) that he investigated using 5mm individual spaces, available from a bicycle shop.
The key is that std monster forks / goldline 4 pots / 320mm rotors use a 10mm offset - changing to the 999 sbk forks increased this to 15mm. Perhaps Suzy can chime in with what she found with the 998 forks, or perhaps it was the rotors she used?
She's right about the fender - the 999 / 749 uses the front and back mounts, whereas the ealier sbks used the std monster mounts. Anyone looking for a used red sbk fender to bolt onto most monsters 9eexcpet the s4rs?
Hope this helps.
