April 28, 2024, 11:09:21 PM
MADDOG
SPEEDO MALFUNCTION!!!
Topic: SPEEDO MALFUNCTION!!! (Read 3537 times)
kp
October 17, 2010, 03:53:52 PM »
I was coming out of Afton this afternoon and hit some bumps. My speedometer needle jumped
a few times and now when the bike is off it's pointed straight down. When the bike
is running, it registers, but it's not correct.
any and all help is greatly appreciated.
Thanks!
~kp~
filter
Bumblebee
Re: SPEEDO MALFUNCTION!!!
October 18, 2010, 09:47:55 PM »
Quote from: kp on October 17, 2010, 03:53:52 PM
Thanks!
~kp~
A similar thing happened to my old Civic. My friend fixed it by smacking the dashboard.
After that, it would periodically do the same thing, and quick smack would get it back in line.
Dealer quoted $400 to fix it, but on a $1k car it wasn't worth it...
01 Monster 750 Dark
(El Matador Tail Chop, Arrow CF exhaust, K&N Filter, CA LED Taillight, Radiantz LED License Plate holder, Blue LED Instrument Cluster, black belt cover, lifted suspension, 14T sprocket, Cycle Cat Billet Side Stand, CRG lanesplitter mirrors, custom Desmo reservoir caps)
kp
October 23, 2010, 09:11:38 AM »
hey! thanks for all the help!!!
think I found the solution tho.
GoTeamV
Boosh!
February 16, 2011, 11:26:03 AM »
Quote from: kp on October 23, 2010, 09:11:38 AM
What did you end up doing?
Dorothy Mantooth is a saint!!
kp
February 16, 2011, 11:33:44 AM »
Quote from: GoTeamV on February 16, 2011, 11:26:03 AM
nothing yet, I was being totally sarcastic!
it still doesn't track correct.
Teutonics
'02 900ie
February 27, 2011, 04:48:04 PM »
Did you get this resolved? Mine just did the same thing today.
A quick search looks like disassembly and superglue the needle to the shaft. Couldn't find instructions on disassembly of the speedometer though...
Atlanta, GA - 2002 M900ie
kp
February 27, 2011, 08:03:00 PM »
no, I didn't!
getting it looked at as soon as it warms up and I can take the bike to the shop.
I'll keep you posted, please do the same?
Teutonics
'02 900ie
February 28, 2011, 05:30:06 AM »
Will do. I hope to take a look at it this week, but could be longer. I'll follow up after I have some results.
Teutonics
'02 900ie
February 28, 2011, 06:25:30 AM »
I found two really good how-to threads, much credit to the OP's!
http://ducatimonsterforum.org/index.php?topic=878.msg25898#msg25898
http://www.ukmonster.co.uk/monster/showthread.php?t=20161&highlight=cracked
Last Edit: February 28, 2011, 06:27:52 AM by Teutonics
Teutonics
'02 900ie
February 28, 2011, 06:42:17 PM »
Follow up (already!): This was a super easy job. On a scale of 0-10 with changing a tail light bulb being a zero, I would give it a one... one and a half tops. This was the entire process:
1. disconnect battery
2. remove two allen screws at base of gauge cluster to allow removal
3. unplug harness from the back. There is a tab at the very bottom of the plug you have to press for it to release. Remove cluster from bike.
4. remove phillps screw at bottom of the back of the cluster. this allows idiot light face plate to rotate up and off.
5. remove torx screw in the middle of gauge cluster
6. separate back from front of gauge cluster. The seals offer some resistance, but it is not glued.
7. release tabs on sides to remove front window face to get to the gauge faces (in my case the tabs were already broken off and rattling around in the back of the cluster)
8. pull needle straight off
9. put dab of adhesive on needle and reassemble as a reverse of above steps
A couple of things that I did to ensure accuracy:
1. before reassembly I plugged the cluster in and checked needle position. I was off about 1-2mph, but this allowed me to place with 100% accuracy.
2. on the needle there is a "skirt" that fits down into a "collar" in the cluster (I assume this is to trap light from coming out around the base of the needle). On mine it was folded over, which may have caused the problem. I trimmed the folded over piece of skirt to make sure it didn't catch (again?).
Really a piece of cake!
kp
February 28, 2011, 06:54:33 PM »
wow that was fast! I'll let you know what I was able to do.
thank you!
