how to install timing belt cover on 696?
Started by mrplease, October 19, 2010, 08:12:06 AM
mrplease
title says it.
how do i install a timing belt cover on a 696?
mattc7
Quote from: mrplease on October 19, 2010, 08:12:06 AM
title says it.
it's pretty self explanatory.  Use an allen wrench, take the bolts off from the stock one, remove the stock ones. Put the aftermarket ones on, and use the same allen wrench to put the bolts back in.
The vertical cover may require removing the tank to slide out.
mrplease
i figured i had to remove the tank skin, but i have to move the tank as well? oh well, i'll get started and look at it once i get home...
mattc7
Quote from: mrplease on October 19, 2010, 10:16:08 AM
You may need to.  I haven't done it on a 696, but the 1100 required lifting the tank alittle.
Once the skins are off, it's 2 bolts, and the tank comes right out. Don't need to disconnect the lines, pump, etc, just lift enough to slide the cover through
jfgducat
mrplease
which timing belt cover are you going with?
Quote from: jfgducat on October 20, 2010, 08:24:33 PM
mrplease
Do tell!
:D
then you guys can totally match!
:D
Quote from: a m on October 21, 2010, 06:15:56 AM
Do tell!
:D
:D
or better yet providius can buy a set for everyone. did he ever make good on those mirrors ;)
Povidius
Oh man... I get a feeling this will never die down!  :-[
with that said, first 100 people get their choice of rizoma or dp carbon timing belt covers!  [laugh]
Povidius
on a more serious note, recently installed mine.  I had to remove my tank to install it.  Wasn't too bad to remove the tank.
jfgducat
Do tell!
:D
:D
So because someone has the same timing belt  they totally match ?
You do realize there are only three option for timing belts
Also remind me again what type of jap bike you have ? FF
