February 06, 2025, 10:17:51 PM *
Author Topic: Kickstand and cyclecat rearsets  (Read 4630 times)
671M900
« on: October 23, 2010, 04:58:12 PM »
So I put on the sexy cyclecat rearsets, and have found that they hit the side stand!! I can adjust them up a little more, but I'm afraid I won't have enough distance to complete an upshift. Any ideas to lower the stand position?
671ducati.wordpress.com Record of Progress!
DarkStaR
« Reply #1 on: October 25, 2010, 02:50:49 PM »
Someone here or on "the other board" added a small plastic block to the bottom of the side stand mounting plate to make the side stand rest a little lower when up.  I can't find the link though.  Undecided
671M900
« Reply #2 on: October 26, 2010, 08:37:58 PM »
Damn, need some ideas here guys! Bend the stand forward a bit? Might take away from it's suicide tendencies.
monsta
Perth, Australia.
« Reply #3 on: October 27, 2010, 04:23:19 AM »
yeah, I had a similar drama with the Lucas reasets. On the lowest setting, I couldn't get my foot cleanly under the shift lever. I tried an SS stand as well as a 748, neither of them were suitable.
I ended up making another mount bracket for the sidestand!
671M900
« Reply #4 on: October 27, 2010, 05:15:05 AM »
As in cut out of aluminum/steel/etc? Damn. I am consisidering bending the side stand in a tiny bit and maybe cutting and rewelding the foot to straighten out.
Omnipotent Potentate
Personal Pretext
« Reply #5 on: October 27, 2010, 08:19:51 AM »
The cyclecat sidestand has an adjustable stop. - you might try adjusting it. It's a 4 or 5mm allen about an inch below the pivot. Look for a little hole on the side of the stand that faces front when the stand is down - that's the access.
loves ze desmodromics.
« Reply #6 on: October 27, 2010, 03:31:06 PM »
GP shift!
Feral 859
« Reply #7 on: October 27, 2010, 08:27:24 PM »
GP shift!
Ding...Ding...Ding
« Reply #8 on: October 28, 2010, 05:16:27 AM »
We have a weiner
671M900
« Reply #9 on: October 28, 2010, 05:37:42 AM »
Hahaha! GP shift, yes why not? Because it'll still hit the side stand on the upshift.
I'm thinking of modding the pivot somehow, Possibly adding a tiny spacer on the end of the side stand, or drilling a hole to make a set screw like the cyclecat stand (which I don't have)
« Reply #10 on: October 28, 2010, 05:42:52 AM »
i don't think it would, but another solution would be to acquire a 2000+ sidestand and bracket, where the spring is located differently and it mounts to the engine case differently. That will solve your problems without need to get creative
