February 24, 2025, 01:48:33 AM *
Author Topic: Recommendation: local machinist or shop  (Read 2043 times)
Autohag
« on: October 27, 2010, 11:49:53 AM »
Looking for a machinist in the area, ideally within an hours drive of DC in case this project turns into back-n-forth.
Failing that, anyone have a drill press and/or metal lathe?
zooom
« Reply #1 on: October 27, 2010, 12:19:41 PM »
what are you looking to do exactly?
2010 KTM 990 SM-T
Autohag
« Reply #2 on: October 27, 2010, 12:51:30 PM »
I will be replacing the forks on my 696. From what I've gleaned from various posts here and on TOB I'm looking at possibly:
- Boring the top triple
- Shimming the bottom triple
- Shimming the axle, and
- Shimming a front rotor (or both)
« Reply #3 on: October 27, 2010, 01:56:43 PM »
Weeeeeeeeeeeeeee!!!!
The Mad King Pepe'
« Reply #4 on: October 27, 2010, 02:58:54 PM »
What forks are you putting on? SBK forks onto a monster used to require adjusting only top and bottom triples (unless they had different caliper spacing from your stock ones).
Autohag
« Reply #5 on: October 27, 2010, 04:57:32 PM »
Well, lot's of options that will work with some shimming. But, ya, I'm shopping used SBK. Regardless, I need a machinist to work with.
Autohag
« Reply #6 on: October 28, 2010, 02:25:17 AM »
Nothing? I might have a line on a guy at RnR Cycles. Does Duc Pond do this kind of thing?
zooom
« Reply #7 on: October 28, 2010, 03:20:50 AM »
YES...Donnie does a LOT of race and custom fabrication...
2010 KTM 990 SM-T
Autohag
« Reply #8 on: October 28, 2010, 03:46:35 AM »
DP is a little out of the way, and I expect their rate will be higher than a generalist. But I know it'll get done correctly I suppose.
rgramjet
« Reply #9 on: October 28, 2010, 04:23:07 AM »
Try Cycles of Silver Spring, talk to Jeremy.  (301)589-2453.  They are on Brookeville Road.
I just had a full service and belt replacement on my ATV.  The price was right with two day turn around.  I remember him speaking of machining some parts.  Not sure if he did them in house or sent them out.
You're obviously a crack smokin' redneck carpenter. Kiss
-Sofadriver
Autohag
« Reply #10 on: October 28, 2010, 04:38:55 AM »
Will do. Thank you! waytogo
