Steel tank internal mystery part
Started by cbartlett419, October 29, 2010, 10:01:35 AM
cbartlett419
So I'm sealing up my tank as the rust is pretty extensive. I've pulled the pump, level switch, and filter and am left with this conical rubber thingy ??? It seems like it was just kicking it at the bottom of the tank. What you see here is how everything looked upon removal. Is there a guru in the house?
sbrguy
looks like it is the bottom of the tank lock tha tprobably broake off at some point if im right it should go on teh bottom of the gas tank opening.
It's just the splash guard. It keeps fuel from splashing up to the cap when the tank is full.
It's only lightly glued into a groove on the cap holder.
Most fall off and remain left off.
cbartlett419
awesome, thanks guys. My bike has been in a million pieces for months, this is the last on my list before it goes to the dyno to be mapped.
It's what DP said. Take the base plate for your fuel filler and flip it over and you'll see the groove he mentioned. You'll also spot a little key for orientation.
BTW - Motowheels has replacement pick up screens. It's that metal mesh, surrounding some fibery stuff that's attached to the end of the fuel pump assembly if you want to freshen it up.
Quote from: yuu on October 29, 2010, 11:48:47 AM
You can also clean them with soap and water and re-use.
I'm cheap. ;D
cbartlett419
herm
i remember finding that rubber cone floating in my gas tank back when i had an m620. i was pretty confused...since i knew i didn't put it in there. luckily the parts schematic told me what it was, and the board (ok, TOB) told me not to worry about it.
[thumbsup]
No more Monster.
Meerkat
I use mine to hold paper clips. At least that way, it's good for something.
'07 S2R1K
'09 Daytona 675
'03 620 Dark-Sold 03/26/2011
DucHead
Was mine swimming around in there by chance?  I haven't seen my splash guard for years.   [cheeky]
cbartlett419
 I was dumbfounded by one, two would have blown a fuse.
