Is there a way to undent the gas tank?
Started by sea bass, June 09, 2008, 07:44:46 PM
sea bass
I bought a 2003 monster a while back, it has 2 dents which the lady said was from moving.  Now I find out it's a common mark from being dropped.  Is there a way to pop them out or should I get a new tank?  What is the tank made of, aluminum?
dlearl476
IIRC, 2000+ have plastic tanks. I have no idea if they can be repaired.
Quote from: dlearl476 on June 09, 2008, 07:53:50 PM
Noooo-the plastic tank is more recent than that.
His should be metal.
Ducpainter can fix them.
There are a number of ways you can do them yourself, but it depends on how handy you is.
Ducatiloo
750 SS 01    800 S2R 05  Aprilia RST 1000 futura
sea bass
ducpainter?  i'll contact him, thanks!
mstevens
#5
My 2005 620 has a steel tank.
If you're asking if it's aluminum because magnets don't stick to it, it's plastic. If magnets do stick to it, it's steel. If it's neither of those, the lady who dented it while moving it also had a tank fabricated from some non-stock material. Prolly solid gold.
My tank got a sweet little dent from a low-side a while back. It was completely repairable for much less than the cost of a new tank and now it looks as good as new.
55Spy
DarkStaR
Quote from: Ducatiloo on June 09, 2008, 08:18:16 PM
Plastic is 2004/05  on up.  [thumbsup]
Most (If not all) 2004 bikes had steel tanks.
Some 2005 bikes had leftover steel tanks.
Uncommon, but possible.
2001cromo
you may get more info/replies for this in tech.
this thread may help in terms of what tanks were when...
http://ducatimonsterworldwide.org/index.php?topic=541.0
regardless, if you want your tank fixed and better than new for a boatload less than the cost of a new tank. Send it to ducpainter you will be very satisfied.
dropstharockalot
You say "Tank Dent," I say "Badge of Honor..."
'96 M900
