February 07, 2025, 01:18:52 AM *
News: Please Help
Author Topic: Removing cooolant overflow/reserve tank on S4Rs. Easy way?  (Read 1151 times)
Billyzoom
I'm having much more fun.
« on: November 09, 2010, 07:16:26 PM »
I want to remove the coolant reservoir to paint it black to it will disappear into the bike, but it looks impossible to get out without removing a bunch of other nonsense.  Any tips?  It's an 07 S4Rs.
Thanks!
booger
« Reply #1 on: November 11, 2010, 11:05:11 AM »
Don't know for sure but those look to be made from polyethylene plastic. Paint won't adhere to it.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
« Reply #2 on: November 11, 2010, 12:37:58 PM »
The proper adhesion promoter will help.
DucHead
No garage queens
« Reply #3 on: November 11, 2010, 02:59:36 PM »
I removed mine and replaced it with a dirtbike overflow container which I hide behind the right radiator shroud.  Alternatively, you could put it behind the steering stem.
Later, I removed the airbox, and did a little more tinkering.  I like the view through the bike:
Bill in OKC
S4Rs
« Reply #4 on: November 12, 2010, 10:29:51 AM »
I went through the same problem.  I had to remove the throttle bodies to get it out.  I read through a lot of adhesion promoter / painting plastic info / some threads on boiling the tank in black dye - also the low expansion coolant, thinking I could eliminate the tank completely - and ended up like above getting the smaller black dirtbike overflow tank and mounting it up by the headstock (no airbox) with zip ties until I can figure out a better way to attach it.  I also tried a 748 upper tank but I could not get it to fit in the S4Rs frame.  I'd like to know how you do.
« Last Edit: November 12, 2010, 10:33:58 AM by Bill in OKC » Logged
