Ok, Cyclecat rearset owners...throw me a bone...
Started by BlackKat, November 10, 2010, 07:21:48 PM
BlackKat
Just picked up a set of previously loved cyclecat rearsets for my 99 750. OBVIOUSLY, I couldn't expect to have an install manual, but can someone tell me (if there is a solution) what you lads have done to utilize the rear brake light switch? I'm certain its been covered, but some fresh talk from active participants would be helpful!
Thanks!
DarkStaR
#1
I don't own cycle cats...but:
If yours looks like this, it looks like the switch is on the bottom behind the spring.
ctrl+ = zoom = command+
Easiest solution would be a banjo pressure switch.   http://www.yoyodyneti.com is a good source.  Call and speak to Fred to get a proper switch for your application.
671M900
Right next to te spring. There a hole in the rear brake master bracket thing for the switch. But the switch I had didn't thread into it, dunno why, haha. My bad, I had the intall manual, but it doesn't cover the switch, just basic assembly.
671ducati.wordpress.com Record of Progress!
