GoTeamV
Boosh!
« on: November 14, 2010, 03:54:06 PM » |
Hello all. FNG question here (post-search I assure you)
I just bought my first Ducati. A 2003 Monster 620.
I am of the mind that what one person can make I can also make. So instead of buying a fender eliminator kit....I chose to "Home Depot" one. Now it seems like my plate keeps getting "sucked" backward and/or scrubbing on the rear tire. I have tried stiffer metals and bending the plate more upward and it still seems to end up rubbing the rear tire somehow.
So now my questions are.....
Am I the only one who has experienced this?
and what are some other options for mounting your license plate? I have seen some guys around town who have their plate mounted further back under the seat, off to the side, etc.
Pics would be great too.
Thanks in advance.
Dorothy Mantooth is a saint!!
« Reply #1 on: November 14, 2010, 03:58:25 PM » |
Thanks in advance.
Maybe your rear suspension is too soft... the farther the tire travels the more likely it will come into contact with stuff above it.... just sayin'
"Once you accept that a child on the autistic spectrum experiences the world in a completely different way than you, you will be open to understand how that perspective is even more amazing than yours." To realize the value of nine months: Ask a mother who gave birth to a stillborn. "Don't piss off old people The older we get, the less 'Life in Prison' is a deterrent.”
GoTeamV
Boosh!
« Reply #2 on: November 14, 2010, 04:09:48 PM » |
That was my first thought so I had the suspension tightened up but still the same problem. I am 6' and 210lbs....hardly an Italian teenager...but I would think that there's an easy fix here. If I pay $100+ dollars on a kit and the same issues occur I may have an aneurysm. LOL.
« Reply #3 on: November 14, 2010, 04:38:39 PM » |
At 6' and 210 you can wind the adjuster on that spring to china and you'll make the same amount of headway as pissing in the ocean. You need to upgrade your rear spring. Spend the money there and your home made plate kit will likely work fine. Maybe Speeddog will chime in, but I'm thinking an Ohlins 12kgm spring. While you're at it search for front springs too. The 620 is a great bike, but they didn't have the 'merican body type in mind when they spec'd the suspenders.
roy-nexus-6
« Reply #5 on: November 15, 2010, 04:32:49 AM » |
Hi, and welcome. I will just point out that if you follow the link below, you will find a thread which lists the tools needed to replace your rear spring (instructional video included). http://www.ducatimonsterforum.org/index.php?topic=32414.0Re. the license plate: did a do-it-myself mod on the tail as well - great fun! Be careful, though - modding an become addictive.
Scotzman
« Reply #6 on: November 15, 2010, 08:07:31 PM » |
Maybe the angle and position you have the mount in addition to the soft suspension. I have my plate angled (45*) so I could have an elephant sit on it and it won't interfere with the plate.
"Get your haggis right here. Chopped heart and lungs boiled in a wee sheep's stomach. Tastes as good as it sounds. Good for what ales you."
mookieo2
« Reply #7 on: November 16, 2010, 07:12:19 AM » |
Get a new spring for $100
« Reply #8 on: November 16, 2010, 03:01:54 PM » |
FHE...
215 lbs 05 S2R 800
NEW SPRINGS!!!
Front and rear.
that is at a minimum. You may want to look for deals on replacing suspension all together.
GoTeamV
Boosh!
« Reply #9 on: November 17, 2010, 08:08:44 PM » |
FHE...
215 lbs 05 S2R 800
NEW SPRINGS!!!
Front and rear.
So what you're saying is....get new springs? I will be upgrading the suspension soon as per the advice I've received here. Thanks guys! In the meantime I will be fabricating a license plate holder that will move it closer to the rear shock. Pics up soon!
GoTeamV
Boosh!
« Reply #10 on: November 28, 2010, 06:16:25 PM » |
« Last Edit: November 28, 2010, 06:49:53 PM by GoTeamV »
SDkid
« Reply #11 on: December 10, 2010, 05:53:15 PM » |
looks decent. Since it's attached between 2 moving parts, how is your license plate clearance between the swing arm?
« Reply #12 on: December 10, 2010, 09:39:32 PM » |
I also have an '03 620. I did my own tailchop and made the eliminator kit myself as well. I bent the plate on the rear tire on 2 seperate occasions. Two other times I came home with the plate hanging by a few wires. Def. get new springs, keep your bolts tight and make sure the cops see your "concealed" plate. The above pics looks cool but the day you're going up an incline with a cop following you, he's going to pull you over cuz the rear tire is blocking the view of the plate. That happened here in Arizona and in Florida. I received a pretty stiff fine for it too in Jupiter.
2018 Scrambler 800 "Argento" 2010 Monster 1100 "Niro" 2003 Monster 620 "Scuro" This just in..IZ is not that short..and I am not that tall.
Langanobob
« Reply #13 on: December 13, 2010, 08:04:05 AM » |
Here is my first attempt at fabricating a solution on my Duc to. I used may of the parts left over from my tail chop. I kinda like the result.
LMK what you think.
Looks good. How about some more pictures of your bike? Kind of hard to piece the whole thing together from all those little fragments!
GoTeamV
Boosh!
« Reply #14 on: December 19, 2010, 01:20:30 PM » |
