Replacing Keyed Ignition Switch with On-Off Switch
Started by junior varsity, November 15, 2010, 07:38:40 AM
I'm looking to ditching the keyed switch in favor of a toggle on/off, like track-only or race bikes. Who/Anybody done this?
I see Mad-Duc seems to have a kit available. I'm looking to do this on my M900, which should be the same as the 748/916/996 / M750 / ST2, though I'm not sitting in front of the ARCO computer, so I am not as well equipped to check.
I see there are four wires that go into the switch I believe. My belief from staring at a wiring diagram is that two are for lights, and one is the master circuit on/off switch.
I would not recommend this for anyone who will park their bike out of eyesight for any period of time, so we can bypass that concern from the get-go. Thoughts?
It's insanely easy.  there are actually 3 wires, one is the ground and splits into 2.
Only one hot is the ignition circuit.  the other is the parking light circuit which you can ditch on a race bike.
I'll still be riding this bike on public roads with headlight and taillight / turn signals, so I need the lights to come on when "on", but I do not (and never have) need(ed) the "parking mode". If that's what you mean.
mattc7
being on the side of the road at night, it's a good idea.
indeed. this is a non-night-time ride, so no worries there.
Mike Qube
Quote from: mattc7 on November 15, 2010, 07:54:13 AM
Not to be off-topic, but has there ever been a use for "parking mode"?
I used it to drain my battery of every last bit of juice it had one day while at work.
I've seen a couple bikes ditch they keys. One, used two switches. One switch was pretty easy to access, the other required one to know where it was as it as quite hidden as a 'security' measure.
Quote from: Mike Qube on November 15, 2010, 09:08:41 AM
that's a good use of it.  you could also just leave the headlight on.  why did you need to drain the battery?
[evil]
MotoCreations
Just replace the ignition switch with a DPST (double pole single throw) switch -- operates two independent circuits ala factory.
I usually look for the higher quality metal and higher amperage switches -- no cheap plastic ones please!  Last thing you want to do is try to shut off your bike in a hurry after a plastic switch breaks.
Quote from: MotoCreations on November 15, 2010, 09:54:09 AM
the DPST switch is needed if you want to preserve the parking lamp circuit, otherwise a SPST is fine.
and double +1 on the metal switch -- that means the base too.
Get a good, sealed MilSpec switch, or at least an oil-spray-tight sealed switch.
For example:
http://www.mcmaster.com/#military-specification-electrical-switches/=9qdokp
The standard auto parts store switches are crap, IME.
OK for non-critical stuff, if mounted inside a car.
found these with a quick search
weathersealed
http://sensing.honeywell.com/index.cfm?Ne=3025&ci_id=154286&N=3668&la_id=1
love the red switch
