November 28, 2024, 08:35:46 PM
153 kg & 85 Hp 696
Topic: 153 kg & 85 Hp 696 (Read 11788 times)
mattc7
Re: 153 kg & 85 Hp 696
Reply #15 on:
November 16, 2010, 09:51:04 PM »
Quote from: Link on November 16, 2010, 08:39:53 PM
more cc's, compression, bigger valves & throttle bodies.
Sounds like the way to do it to me.
Reply #16 on:
November 16, 2010, 10:12:18 PM »
compression is pretty high already.
valves.. can't go bigger and get more power (per a noted Ducati engine builder)
throttle bodies are the same as on the 1100 so doubt that is needed but can be opened a mm or 2
could be stroked to the 803.
the port polish, cams and tuning should help alot.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Reply #17 on:
November 17, 2010, 03:32:58 AM »
Quote from: greenmonster on November 15, 2010, 10:05:31 AM
Engine mods: Ported, camtiming & mapped w RapidBike. Slipons & open airfilter.
65,83 Hp/62.88 Nm at start, 85.56/78.75 after, same bench.
Although I struggle to beleive you can get 20hp from the engine mods identified here.
Quote from: Dan on November 16, 2010, 02:15:37 PM
20 HP, a 30% bump, with just porting, cam timing and a map?
+1?
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
greenmonster
Reply #18 on:
November 17, 2010, 08:13:42 AM »
All info is from the owners writeup, incl engine mods.
What can I say, noone over here hardly believes i either!
The tuner has ported & modded Ducs f over 20 years, works w racing teams etc:
http://www.proservice.se/indexe.html
--> Dyno, scroll down you see the 696 chart here also.
My first Q to owner was what the tuner thought about the ports, maybe the secret?
He`s apparently climbing K2 again or something, answers will take a week or two.
M900 -97
MTS 1100s -07
Online
Feral 859
Reply #19 on:
November 17, 2010, 05:39:28 PM »
Quote from: ungeheuer on November 17, 2010, 03:32:58 AM
+1?
+1
mattc7
Reply #20 on:
November 17, 2010, 06:57:48 PM »
rapid bike doesn't even admit a 696 fitment, so this is interesting in multiple levels. If there's 20hp to find in the 696, i'ld be very impressed. I can't imagine getting that much with so little though
Desmojet
Reply #21 on:
November 17, 2010, 08:13:15 PM »
Quote from: mattc7 on November 17, 2010, 06:57:48 PM
http://www.rapidbikeusa.com/wp-content/uploads/2009/03/application-list-rapid-bike.pdf
Monster 696 2009 / MWR+Reflash / S4 wheels / CNC Racing Rearsets/ Stainless Termi / Pazzo shorty / DP LED turnsignals / DP short tail / Rizoma bar end mirrors / Diesel seat / Carbon here and there ....
Link
Reply #22 on:
November 17, 2010, 09:09:41 PM »
Quote from: Raux on November 16, 2010, 10:12:18 PM
Yeah, I don't know the 696 well enough to know it's exact physical limits I'm just saying you cant get that much HP increase in a small motor with the mods listed if you could pump up a 696 to over 80 hp with a cam, port & polish you would be a rich man. Stroked to an 803 well that is no longer a 696 and with out bigger valves you still would prob. be shy of the claimed 85 hp. I'm not sure but I thought the 796 (a stroked 696) is only putting out about 5 more hp then the 696.
hcomp
All this time I wondered what it was like to have a
Nothing to see here
Reply #23 on:
November 17, 2010, 10:25:06 PM »
An interesting question for everyone regarding the dyno graph, why does the torque and HP curve not cross at 5250rpm?
にもかかわらず、私の車は本当に速いドライブ、私は女性の生殖器のようなバイクに乗る
csp808
Reply #24 on:
November 18, 2010, 03:19:38 AM »
Quote from: ryanracer on November 17, 2010, 10:25:06 PM
That should be a given unles the rpms are measured metrically.
greenmonster
Reply #25 on:
November 18, 2010, 10:29:02 AM »
Quote
From
http://www.visi.com/~moperfserv/Torquething.htm
Quote
The equation for calculating power from torque and RPM is; torque (in
pounds-feet
) times RPM divided by 5252.
Proservice uses Nm. All his graphs cross at same RPM. And something w graph resolution maybe,
I`m not sure about this.
Mailed tuner and asked if there were only the 3 mods done and what contributed the most.
Bit short answer: The whole picture decides it, the porting did the most of it.
So maybe it`s the old "It`s all in the head" again.
And knowledgeble mapping
do
make a difference.
Last Edit: November 18, 2010, 01:35:58 PM by greenmonster
M900 -97
MTS 1100s -07
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Reply #26 on:
November 18, 2010, 06:15:58 PM »
Quote from: greenmonster on November 18, 2010, 10:29:02 AM
do
make a difference.
Nobody would deny that. But 20hp??
Does it have a turbocharger?
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
hcomp
Nothing to see here
Reply #27 on:
November 18, 2010, 10:14:36 PM »
Quote from: csp808 on November 18, 2010, 03:19:38 AM
Wow, I wondered why my tach was off! Of course Metric RPM! I'm going to recalibrate my tach for Standard RPM does anyone know how to do this on a 696?
Now for the real question, at what RPM does NM cross HP? I see the point, and I can understand it crossing at a higher RPM than Ft.lb. but does anyone know the constant?
greenmonster
Reply #28 on:
November 19, 2010, 05:29:09 PM »
One lb/feet torque is 1.35 Nm.
1.35 x 5250 = 7087.5
Seems pretty close to cross in the graph I posted, maybe it is that simple?
Last Edit: November 19, 2010, 05:33:45 PM by greenmonster
M900 -97
MTS 1100s -07
battlecry
On a silver black phantom bike...
Reply #29 on:
November 20, 2010, 05:32:29 AM »
That's about 122 hp/liter. Same neighborhood as the Honda S2000. Color me pretty impressed.
Taking one of Ducati's highest Hp/disp bike and bumping it 20hp is a big deal. Especially claiming no internal mods.
I do not believe the cooling system would cope well with rejecting the extra heat. Let us know how long the engine lasts.
