Wrapped around the axle...
Started by DTR, November 15, 2010, 05:57:37 PM
DTR
I've managed to sell some parts and raise some capital to get the Monster moving towards assembley. Started to look at the rear wheel and noticed it had a flat spot in, most likely from the crash landing. I thought about having it straightened and compared that cost with buying a used one off the on-line auction place. Great ,got a good deal on a replacement wheel.
   It arrived and the first thing I notice is an elephant cast into the wheel, uh oh, older than I thought. THe next thing I notice is the bearings are smaller than the original and, of course the axle in a smaller diameter. So by being cheap, have I F*cked myself, or can I use this wheel if I find a smaller axle and tensioners? (both wheels are 5.5")
corey
sell it off and find the right wheel. it will be cheaper, and easier.
Pedro-bot
What year/model monster do you have?
monsta
you should be able to get bearings to fit the larger dia axle, but I think they may be narrower width so you'd have to get a couple of spacers made and a longer crush tube in between the bearings.
probably easier to sell and re-buy like corey said...
DTR
Mine is a 2000 900sie. I don't know which year the "deal of hte century" wheel came from. DOH!
The older wheel and axle are heavier.
