February 23, 2025, 10:58:35 PM
Please Help
Too Cold to Start or Need Starter???
Topic: Too Cold to Start or Need Starter??? (Read 1620 times)
c1fer
November 17, 2010, 12:42:48 PM »
To the point:
Its November in San Francisco, not too cold. maybe 50's in the AM.
I charged my Battery all night (over 10 hours). Also filled the water level first.
When I replace the battery and start my 99' M900, the clutch barely turns over. Like maybe half a turn.
I turn off the ignition and repeat. Sometimes it will start, but the last 2 days it didnt. even when I have the battery charged clamped onto the battery.
1. is it just too cold?
2. Do I need a new Starter?
3. Do I need a new Battery?
4. Do I need to wrap an electric blanket around my engine??
Does someone need to explain to me the mechanics of a cold start?
Thanks
Re: Too Cold to Start or Need Starter???
November 17, 2010, 12:45:24 PM »
How old is the battery?
November 17, 2010, 12:48:02 PM »
Fully charge the battery and take it to a shop to have it load tested. If it fails the load test, replace it. It is not too cold.
c1fer
November 17, 2010, 01:02:03 PM »
i have a feeling its the battery too... I will have it tested. it's almost 2 years old or older.
By the way, I did noticed that when the battery was drained this summer, the water levels were very low.
is there a "no maint" battery for motorcycles where you don't have to fill it with water all the time??
Thanks
c1fer
November 17, 2010, 01:05:09 PM »
One more thing...
Where can I buy a Battery tonight, after 6PM.
in BERKELEY, OAKLAND East Bay???
Thanks
November 17, 2010, 02:42:31 PM »
Quote from: c1fer on November 17, 2010, 01:05:09 PM
One more thing...
Thanks
Post up in the San Francisco board:
http://www.ducatimonsterforum.org/index.php?board=19.0
victor441
November 17, 2010, 05:33:08 PM »
One more thing...
Thanks
Cycle Gear SF is open until 7.....FWIW the Santa Rosa store had the correct Yuasa for my Monster, would not go w/ a cheap battery, the new one my bike came with failed within months...the Yuasa was expensive but worth it in my experience
Teutonics
'02 900ie
November 19, 2010, 05:45:02 AM »
Probably the battery, but one other suggestion: check all the connections (cables to battery, cable to starter, etc.) and clean to remove corrosion and ensure contact. I've had bad connections produce the same results before.
Atlanta, GA - 2002 M900ie
c1fer
November 19, 2010, 04:18:23 PM »
Berkeley Yamaha / Honda: Yuasa YB16AL-A2, $89.00
And wouldn't you know it, a storm rolls in and for the next 4 days..lol
greenmonster
November 19, 2010, 05:09:12 PM »
But did it start w new battery?
M900 -97
MTS 1100s -07
DG
November 20, 2010, 11:50:47 PM »
Live in AZ and leave both Ducs on Bat Tenders for days and they won't start when sleeping in a cold garage.
Roll them into the sun for an hour or so and BOOM...no problem. Bats are young and full so I say the Duc doesn't like the cold. Big pistons & small battery. Starter takes almost all the amps the bat can store and will draw it near dead with a few start attempts. Had a mech buddy give me a good tip tho...take the engine to frame ground wire off and install one of a larger gage. It seems to have helped as larger wire provides less resistance The bikes seem to crank harder & faster and the battery doesn't fall flat on numerous attempts.
2-bits complete...good luck!
PS: Walker-Odessey makes a great battery. No sevice-no water-works in any position except upside-down!
"I'm really busy with something not important."
Greg
November 21, 2010, 08:49:37 AM »
Might help to swap out the battery/starter cables with some heavier duty units to let more current through.
2012 M1100 Evo with Termis
