pressure switch
Started by jerryz, November 20, 2010, 08:33:04 AM
jerryz
The pressure switch on my S4 has sheared at the bolt ,damn thing was only hand tight when it bust , I have temporary fitted an old spark plug in the hole as its same thread so i can use the bike , seems Ducati Thailand dont stock it so i will order one from UK which will take a month to get here if not stolen in the post but are there any cars that use it so i might try some local parts store GM, FIAT etc or the generic make of the switch ..also i may try repair with steel epoxy but not holding my breath
__________________
MONSTERMAN
The oil pressure switch is an M10x1 thread.
IIRC the same switch is used on some Fiats.
The "Alternatives to expensive Ducati parts" thread here:
http://www.ducatimonsterforum.org/index.php?topic=698.0
May have the info.
VW has switches that will fit also, but the connector is different.  Most car switches are set at a lower pressure.
jerryz
Yeah I have been looking thru old threads , plenty of info and possible options , i need 10mm fine thread and 0.3-0.6 bar or as near as .
will look tommorow there a chinese car parts lady who can usually get anything I will ask her
