February 11, 2025, 08:28:57 PM
Oil/Fuel Stains on Engine Case
Topic: Oil/Fuel Stains on Engine Case (Read 2272 times)
cakeman
November 20, 2010, 10:32:03 PM »
I have some oil and fuel stains on the engine cases as well as some grit/dust around the circumfrence of my open clutch, which i inherited when i bought my S4R, i have tried pretty much everything i can think of to get rid of it or to even get a little off, but to no effect.
Does anyone have any tips, tricks or suggestions, short of getting it resprayed.
Thanks
Flickr Photos
J5
I'm here to fix zee fridge
Re: Oil/Fuel Stains on Engine Case
November 20, 2010, 11:26:05 PM »
no first hand experience
but if it wont wash off then you have to go further
i would look at some polishes
further from there either jiff or gumption creme cleansers
usual rules apply test on an inconspicuous spot , maybe bottom of the sump ?
iirc i read on a can of bon ami cleaner guarenteed not to scratch
November 21, 2010, 10:40:15 AM »
ive had zero luck with getting oil stains of my engine, they are caked on there pretty good. I was going to strip it and repaint it with something thats more resistant to oil. cause whatever ducati uses is flaking off.
Grrrly
Industrial Grrrl
November 21, 2010, 12:45:50 PM »
I don't know what you have used so far. I've used some undiluted Citri-Solve (from my job, don't know brand) and it cleaned mine up with no scrubbing. This stuff is probably the same as the citrus based Engine-Brite. But again, I don't know what you have tried so far.
Best of Luck
The Evil Twins:
Urban Assault Vehicle:
2002 Duc M 6/900 Industrial Edition
Track Weapons:
2004 Suzuki SV650
2009 Kawi ZX-6R Monster Edition
vossy
South OZ
2007 S2R1000
November 21, 2010, 02:10:50 PM »
Mag wheel cleaner does it for me. The only thing is that you need to rinse it down with water afterwards (with in a couple of minutes or so)otherwise you risk having the paint come off.
It got tar off my lower part of my engine case with ease.
Last Edit: November 21, 2010, 03:37:51 PM by vossy
"Life's short" "Ride More"
mendoje
November 21, 2010, 02:28:46 PM »
Try clean gasoline, IME it easily dissolves baked and varnished oil. Just be careful, dont be smoking or anything like that.
2003 M800Sie / 2004 BMW R1100S / 1981 BMW R100RS (Sold) / 1977 Kawasaki KE100 (1st Bike
http://ducatimonsterforum.org/index.php?topic=27788.0
loves ze desmodromics.
November 22, 2010, 06:34:58 AM »
Quote from: mendoje on November 21, 2010, 02:28:46 PM
no fun
zooom
November 22, 2010, 09:22:30 AM »
have you tried S100 or Castrol Super Clean Degreaser?
2010 KTM 990 SM-T
November 22, 2010, 09:26:23 AM »
'skrat gives the dirty parts a quick wipe down with denatured alcohol i think to get dirt and grime off when its fresh. his s4r has plenty of miles on it and looks clean enough to eat off of. thats more preventative than damage control though
671M900
November 24, 2010, 05:03:52 AM »
I have a dremel carbon steel cup brush I use on my die grinder, very soft, takes a fair bit of effort to take off paint, but light pressure takes off stained oil and fuel for me.
671ducati.wordpress.com
Record of Progress!
Mr Earl
2003 M800 Dark
November 24, 2010, 06:15:04 PM »
My bike had oil drip stains from the fill plug, and gas/carbon stains on the clutch cover from the old emissions tubes (don't ask), both of which defied every attempt and cleaning agent. Until Simple Green. For years I refused to try this stuff, thinking it was some ineffective biodegradable foo-foo crap. But it works! Rinse promptly and thoroughly, though, it's corrosive if left on for a while.
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
badgalbetty
its never too late to be who you might have been
November 26, 2010, 08:57:40 AM »
total cycle cleaner S-100 is my cleaner of choice for road bikes. If you have stubborn stains a stiff bristle brush after you have sparayed the s-100 on will usually free up any krud. For dirt when I worked for Suzuki many years ago, we used Westleys bleach white , but make sure you wash that crap off in zero seconds. It is very corrosive to plastics and alloys but boy does it get rid of dirt!
cakeman
November 27, 2010, 02:32:28 AM »
Ive attached a pic.... see the engine case in the right of the pick (under the clutch), it is very orange, yellow...... I was told today that it might be from the head of the oil INSIDE the case doing the damage to the exterior paint.........
Flickr Photos
battlecry
On a silver black phantom bike...
November 27, 2010, 06:11:24 AM »
Gosh, that orange takes the cake. (Sorry cakeman) Some Aluminum alloys have some documented porosity, mostly to gases, so that may be a stretch. More than likely it is caused by lowest-bidder paint supplier to Borgo Panigale. The heads in my 800 have similar burned paint around the exhaust ports.
Last Edit: November 27, 2010, 02:13:08 PM by battlecry
cakeman
Reply #14 on:
November 27, 2010, 01:15:42 PM »
Quote from: battlecry on November 27, 2010, 06:11:24 AM
Gosh, that takes orange the cake. Some Aluminum alloys have some documented porosity, mostly to gases, so that may be a stretch. More than likely it is caused by lowest-bidder paint supplier to Borgo Panigale. The heads in my 800 have similar burned paint around the exhaust ports.
So is there anything i can use to fix/minimise the discolouration?
Flickr Photos
