Rizoma Rearsets?? Brake Bleeding info...
Started by cakeman, November 25, 2010, 03:10:13 AM
cakeman
H guysi, ive just installed the brake side rizoma rearset with out to much trouble.. the problem is that my rear brake has only approx 5mm of play in it now..... Im assuming the brakes need to be bleed? Also i need to lengthen the whose from the brake fluid cyclinder to the master cylinder (hose was included in the rizoma rear sets)..... for full adjustmeants of the rearset the hose needs to be lengthed.....
ive never bleed brakes before and am a little frightened of fluids
Im assuming that i can connect a hose to the rear caliper nipple, crack the nut and drain ALL fluid in to a cup or something....
Once all fluid is drained, i can lengthen the hose from the fluid resvouir to the master cylinder.
Once that is done... im a little lost on the process on how to bleed/fill the cylinder up with brake fluid? ive looked around but cant find any definitive way of doing it with out getting brake bleeding kits etc......
Also, when the bike was serviced a month ago, fluids were done, so im assuming it will be fine to use the same brake fluid?
Any help would really be appreciated.
Thanks!
techno
once you reassemble the rear brake set up fill the reservoir and leave the cap off. Then put the bleed hose back on the bleed nipple. push the lever and open the nipple to let the air out then close nipple and release lever. Repeat until you only get fluid out the nipple and no air bubbles. Make sure the level of fluid in the reservoir doesn't get down too far, keep topping it up.
Brake fluid works best when its new so I wouldn't re-use the old stuff. Its not that expensive.
Good luck and thanks for the opportunity to use the word "nipple" so often in one post.  [laugh] :P
Quote from: ducmeister on May 24, 2012, 01:45:16 AM
Hey Techno you are a smart man.  [thumbsup]
Had an accident in Tasmania? - www.tas-compo-law.com.au
cakeman
Quote from: techno on November 25, 2010, 03:21:10 AM
hmmmmm.... so to lenghten the hose between the resovouir and the master cylinder..... crack the NIPPLE and let all the fluid drain?
then close the nipple, lengthen the hose to the right length.
So now there is no fluid at all in the system..... have the NIPPLE closed and fill the resoviour...... connect bleed hose to nipple... crack the nipple and THEN push down on the brake???
i get a bit lost on this part....
mattyvas
braando
Andrew.......by any chance, do you possibly posess a trailer capable of transporting a bike mate..??   ;D
Like i said, i was only a phone call away........!
The Rearsets from Michael were a straight take off/bolt on procedure.......hmmmmmmm......
cakeman
#5
It's rideable, it's nothing major. I just won't touch the rear brake otherwise I'll be leaving some black lines on the road! You working this morning Brian? Is your son in law around :)
braando
Andrew........he is up nth till Sat, but am sure he would help then.......I am working at Shauns house today so i will mention it to him......I am sure tho, that if you called in to their workshop they could recitfy your pho par in minutes.........
"nipple"       [thumbsup]
cakeman
i should have realised that before un screwing bolts on the gear side that one of the bolts is connected to the kick stand.... silly me didnt use a paddock stand.... bike almost toppled over.... IM A NIPPLE!
Thought id give a go of putting my rizoma grips on... looks like a pain in the ass, for the non mechanically minded like me.... might wait for help!   [bang] :)
NIPPLE
ozducati
Cakeman.. put the tools down and back away .. slowly... pick up the phone and call a professional... then put all your tools out on the nature strip and i will come and collect... ;D
cakeman
Yep you got it. Thats what I'm going to do!
Other then put petrol in I'm useless at all that stuff!
But it gets me away from the misses..... That's why I stupidly persist!
ozducati
Mr Sheen is your friend in the garage... [laugh]
you can still get away
Quote from: cakeman on November 25, 2010, 05:37:15 PM
Betty
Other than put petrol in I'm useless at all that stuff!
Join the club, although sometimes I struggle with the petrol.
One of us has got it wrong. I generally hand box of bits to the missus and only go out to the garage once its done ;D
braando
Cakeman slash Andrew......if your "Missus"ever finds your password and just happens to open this thread.....then i feel that a precious part of your manly anatomy could be adorning your Christmas tree mate....... ;D ;D ;D ;D   By any chance we have a christmas party......gee.....i would love to meet her and have a chat........ [evil] [evil] [evil] [evil]
cakeman
Quote from: Brian W on November 26, 2010, 12:55:39 AM
What Thread... GEE has someone hacked my account again????  [laugh]
Wells
2005 M620
Hi. I’m Troy McClure. You may remember me from such self-help tapes as “Smoke Yourself Thin” and “Get Some Confidence, Stupid!”
NYTimes: "...highlights of his global tour include encounters with Nelson Mandela, an 800-year-old demigod and a dildo collector."
