February 24, 2025, 11:57:48 PM *
News: Please Help
Author Topic: Broken Horn Switch  (Read 1160 times)
Timmy Tucker
Banninated
« on: December 05, 2010, 08:34:43 AM »
Due to the bike being dropped by both myself and previous owners, the horn button is smashed into the control housing and no longer works. I was wondering if anyone had successfully repaired a broken horn switch? I can't afford $200+ for a new set of left hand controls, and can't seem to find a used one w/o the same problem.
I generally have no qualms about tearing into stuff to try and fix it, but I'm a little hesitant to tear the controls apart and possibly fubar the whole control assembly. Anyone have experience with this?
1999 M750 - "Piggy"
2007 S4RS
battlecry
On a silver black phantom bike...
« Reply #1 on: December 05, 2010, 08:54:28 AM »
Enjoy:
http://www.4strokesonly.com/Switches.html
« Reply #2 on: December 05, 2010, 09:05:24 AM »
The horn switch contacts are held in position by a tab and a screw, if the button is pushed *hard* the tab can pop out of the slot in the housing.
Some times need to straighten out the contacts as they can get bent in the above scenario.
Requires a bit of fiddling around with small parts, and a good small phillips screwdriver.
Timmy Tucker
Banninated
« Reply #3 on: December 05, 2010, 10:21:46 AM »
Well that was easy. Took about 5 mins to disassemble, fix and reassemble. Thanks!
1999 M750 - "Piggy"
2007 S4RS
live2ride
monster 750 dark
« Reply #4 on: December 13, 2010, 06:09:08 PM »
just fyi for those that got here from searching as i see you already fixed your issue
i've been having some issues with the horn switch myself. after tearing into it, i realized that the contact plate the button makes contact with moved further away from the switch.  now the button no longer makes contact due to a further distance if this makes sense.
to correct this, i had to shove some neatly folded electrical tape behind the plate to prevent it from moving away from the button.  works 100% of the time now
ScottRNelson
Mr. Dual Sport Rider
« Reply #5 on: December 17, 2010, 04:03:23 PM »
As a reference point, I've disassembled the horn switch on the 1998 ST2 that I used to own twice to fix it.  (The ST2 used the exact same switches as the Monster.)  The first time it stopped honking the horn and I opened it up to clean up the contacts a bit.  The second time it was at the point where it worked most of the time, and I pushed the switch too far in while trying to honk at some moron on a cell phone who cut me off and was totally unaware of what was going on.  I had to bend things a bit and use a file to clean up the contacts to get the best operation.  Hopefully the new owner of that bike has no further problems with the horn.
