Let Me See Your Monster Bling/Mods!!!!!
Started by lofty55, December 07, 2010, 10:30:33 PM
lofty55
QuoteLofty, if you find yourself thinking about heading out to Ojai/Highway 33, drop me a line.
Will do. Nice S2R... i love the DS1000 motor.  [thumbsup]
QuoteLove it.  I love the tangerine with the black frame and wheels.
Thanks. The tang bodywork was an ebay buy. 500 bucks and i got the complete set. Which one of you bid against me?!?!?! i almost got it for 300. hahah.
QuoteLet's see a few more pics.
Awwwe man, i guess ill have to clean it up and snap some more pics. Had some wet mornings here lately.
This is more fun than standing still at a radiohead concert.
'07 S2R1K
'02 998
orangelion03
Quote from: lofty55 on December 08, 2010, 06:24:03 PM
Well as you might considering you are on a 1K, but I'm "stuck" with a measly little 800  [moto]
VIVA LA EVOLUCION!!!
lofty55
QuoteWell as you might considering you are on a 1K, but I'm "stuck" with a measly little 800
ah no shit huh... a lot i know. 800s had the cool colors... like tangerine red...... ;D
'07 S2R1K
'02 998
rockaduc
Quote from: Billyzoom on December 08, 2010, 08:25:33 AM
Hero mistake...."loose" instead of "lose".  Of course, if the reflectors are loose they may fall off on their own.
Damn it guys... :P
Quote from: lofty55 on December 08, 2010, 03:54:18 PM
i think you mean warlock.... a male witch
(damn girlfriend has got me watching to much vampire diaries haha.....  [thumbsdown])
Los angeles traffic sucks, I feel like i should leave them on as i commute at night very often
you actually can get reflective colored tape that is less obvious but more reflective
duc996
       "Monster S4r"
       "KTM SMC 690"
I don't think I can list all the things I've done to the M900 over the years in a single page
In its current form:
IMA billet upper & lower triples - 30mm offset
SBK Forks with Ohlins Internals
Penske 8983 Rear Shock
Ohlins steering damper
MW billet under triple damper mount
TPO lightweight aluminum front axle
Ti axle nut, brake caliper bolts, adapter plate bolts, rotor bolts, triple pinch bolts, axle pinch bolts, fender bolts
NCR-Sil Moto Pipes
Sil Moto Spaghetti Headers (ceramic coated)
ceramic coated intake manifolds, titanium nuts, titanium vacuum plugs
keihin fcr41 banked carbs
dyna coils
ignitech tcip4 sparker programmable ignition
pod filters
ngk plug wires
carbon battery box / coil mounting bracket
AG Hammer Power Pulse Box
carbon undertail
dp/dpm billet valve inspection covers
dp/dpm billet cam end covers
rizoma oil cooler guard
nichols flywheel
nichols billet breather with k&n filter (no vent tank)
custom oil cooler lines
veetwo lightweight billet adjustable cam pulleys
veetwo lightweight billet clutch basket
veetwo lightweight billet clutch hub
rizoma pressure plate
rizoma clutch cover
rizoma belt cover
rizoma mirrors + adapters
rizoma reservoirs front/rear brake + clutch
rizoma front turn signals (avio 21)
vizitec tailight with integrated signals
custom tail chop
upgraded starter, starter relay, frame ground & engine ground wires
rizoma/febur billet suspension hoop
corsair billet axle adjuster plates
rizoma rearsets
woodcraft clipons
DP carbon sprocket cover
DP carbon headlight brackets
DP carbon rear hugger
DP slave cylinder
BST carbon front wheel
BST carbon front fender
AMS billet 65mm-to-40mm caliper adapter plates
ISR 6-piston billet monoblock calipers
ISR front rotors
Motomaster rear rotor
Spiegler front/rear brake & clutch lines
Brembo billet GP 16x18 radial master cylinder
Brembo forged GP 19x18 radial master cylinder
SSR skeletonized billet offset reverse shifter
SpeedyMoto Alternator inspection cover
DP carbon gauges with tachometer (now on the 2d 900 Monster in the garage and this bike is gaugeless, in wait of motogadget)
Bellypan
custom paint
Euro-Racing Quickturn throttle with custom Motion-Pro push/pull lines
Euro-spec Ducati left hand switch assembly
speedbleeders
ti rear axle nuts, rhinomoto rear axle sliders
nichols motor mounts
crankcase oil-fill temp gauge
sargent seat
mw billet keyless gas cap
mw billet triple stem bolt (revolver style)
nirvana drainplug
billet speedo-drive replacement spacer
keyless ignition
vacuum petcock replaced with standard manual petcock
upgraded stainless braided fuel lines
parts-in-waiting:
u-bracket replacement that's not a u-bracket
veetwo lightweight primaries
veetwo high torque (-212) grind cams
mbp collets
titanium clutch basket bolts
factory pro 'pro shift kit' (Factorini Provente [laugh])
discacciati billet rear brake master cylinder
brembo billet rear brake caliper
851SP corsa rear adjustable rocker, ti rocker pivot, ti top shock mount
billet rear axle adjusters (the part that goes inside the swingarm) with ti bolts
there's both more parts on the bike left unlisted and more parts for the bike on the shelf.  no current pictures of the whole bike together currently.
Justo
Quote from: a m on December 09, 2010, 09:47:09 PM
NCR-Sil Moto Pipes
dyna coils
pod filters
ngk plug wires
carbon undertail
nichols flywheel
rizoma clutch cover
rizoma belt cover
custom tail chop
rizoma rearsets
woodcraft clipons
DP slave cylinder
ISR front rotors
Bellypan
custom paint
speedbleeders
sargent seat
nirvana drainplug
keyless ignition
parts-in-waiting:
mbp collets
[bow_down] [bow_down]
though you know what they say about no pics...
09 Black Ducati 696
a m's carbon battery box is a particularly nice feature. Made it himself.
lofty55
#24
duc996, which model is that? white rims and big radiator thing makes me think s4???
QuoteI don't think I can list all the things I've done to the M900 over the years in a single page
dont tease, show us some pics.
'07 S2R1K
'02 998
duc996
#25
lofty55 that is an 04 s4r:-) great bike man!!! just way too much power for me.Still can't tame it:-)
       "Monster S4r"
       "KTM SMC 690"
(i was awaiting a new brake line for these calipers when this was taken)
(ncr clipons were put on temporarily to wheel bike around garage - they are for another project)
(carbon undertail)
(non-current photo)
(making the carbon battery box)
i should note that the bike also has a nichols billet rear brake caliper bracket (redirects it to the top from the bottom on my year bike, making bleeding about.... 200% easier)
And a desmoworld clear headlight
AM can you pm me your source for CF. I want to try and make some pieces, but not sure where to get fabric and epoxy
Twizted
A M. Your monster is absolutely beautiful. Love the old school Ducati decal on the tank. Do you mind if I steal that idea? Might be purchasing a 1000ie with a tiny ding in the tank.
muskrat
Quote from: Twizted on January 07, 2011, 10:55:55 PM
do it, he will change it again in a week's time.   [laugh]  the man has a worse case of OCD than I do.  8)
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
