Competition Werkes tail chop instructions
Started by NvrSummer, June 10, 2008, 06:24:12 PM
NvrSummer
Anyone have a set of Competition Werkes tail chop instructions they could scan and email?  Bought a used kit, and although I'm pretty handy, want to make sure I don't overlook anything.
I'll even buy ya a beer if you're in CO!
Thanks in advance.
LYD
I did a comp werkes on the old bike and followed the instructions, but I really didn' need them  it was pretty easy!!  But I'll look for them!
RIP cdc
01 900 monster
01 748
02 900ss (trackbike)
12 1200s Multistrada
NvrSummer
Quote from: littleyellowduc (LYD) on June 10, 2008, 06:35:58 PM
Yeah, that's kinda what I figured.  I just have that nervous feeling about chopping the frame without some instructions written by someone way smarter than myself!
RavnMonster
If you are patient I may be buying that kit in the next few weeks or so. Ill shoot it to you. Shoot me a PM in about a week or so if you still need them.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
-- Eleanor Roosevelt, First Lady of the United States, 1945
NvrSummer
Quote from: RavnMonster on June 10, 2008, 08:49:00 PM
Eh, not sure I can wait much longer!  Must... cut.... tail!!!!
Grappa
NvrSummer-
I just PM'd you my email address.  I can email you the instructions when I have your address.  I just chopped the tail on my 2001 M900.
Ahh... but the servant waits, while the master baits.
Sometimes Aloha means Goodbye.
robartlum
Im in the same boat! Im looking to chop the tail off my 99 m900 but am very cautious without any detailed instructions! If anyone can help me out, I would appreciate it!
robartlum@gmail.com
1999 m900
NvrSummer
Quote from: Grappa on June 12, 2008, 10:53:31 AM
NvrSummer-
Replied to ya!  Thanks much!
CF_Beast
Did anyone have to bend the right side inward to kinda get it to where the nut comes out (coming from below)? I just noticed that on mine the bracket the signal is attached to starts behind the tail light as opposed to flush with it (like the left side). I was wondering if I got the defective one (from CW) or if its standardly defective... in other words, just part of fitting it in.
I guess I could just remove the bolt, bend it back, and have the bolt tightened so as to hold the bottom part only.
2005 S4R, Rizoma Lux Grips/Bar Caps, ASV Shorty Levers, DP LED Mirrors, CF Headlight Brackets, Rizoma Clutch Cover/Pressure Plate, Stebel Nautilus horn (139db!), Rizoma Sprocket Cover, EK Chain (Red), Shift-Tech CF Chain Guards/Rear hugger, CW Tail Chop, LED Brake Light, Watsen Design tail signals, Zard Full Exhaust. My wife was OK with the bike until I started spending money on Her, not her... Now I just call her Francesca and say she's my Italian mistress.
NvrSummer
I had to use different mounting points on each side for the signals.  On one side I used the inside mount, and the outside mount on the other side.  That's the only way the signals would align with the taillight.
You'd think they would've got that right by now.  Guess not.
CF_Beast
Do you mean to say you took the part that is supposed to run vertically (with the signal attached) and laid it horizontally, using the horizontal as the signal bracket? Then there are no factory issues with the chassis. I bought a demo bike from the dealer, so all sorta things ran through my head. Maybe thinking somebody had totalled it before they transfered it or during a test drive... However, I know Italians are very good at styling, not necessarily workmanship so every factory condition could come with it kinks here and there. Just take a look at all the welding on the single swing arm on the S4R models, for example...
NvrSummer
Quote from: CF_Beast on July 14, 2008, 09:57:21 AM
Not quite sure what you're asking, but the signal tabs have two holes drilled in the horizontal leg that attaches to the plate holder bolts.  On one side I had to use the inner screw, the other side I had to use the outer.  Does that clear it up?
CF_Beast
I know exactly what you mean... and it means I'm screwed! The problem side has the screw that puts it farthest out. I would basically need it to be longer to have it sit like it should. Oh, well... I'll have to be creative.
