January 20, 2025, 06:32:56 AM *
Pages: 1 [2]   Go Down
Author Topic: '07 S4Rs Speedometer problem  (Read 5204 times)
DoubleEagle
« Reply #15 on: June 11, 2008, 08:56:38 PM »
Just to confirm:
Does the tach needle work?
If it does, check the speedo pick-up & wire on the swing arm.
Hint:  There's only one wire on the swingarm.
        Tach works fine.  Where does the speedometer connect ...doesn't it connect to the front wheel somewhere ?
« Last Edit: June 11, 2008, 08:59:25 PM by DoubleEagle » Logged
DarkStaR
« Reply #16 on: June 11, 2008, 09:37:14 PM »
Scratch that, it "should" sweep regardless.
I'm out of ideas.    Huh?
DoubleEagle
« Reply #17 on: June 11, 2008, 10:13:00 PM »
Just to confirm:
        I thought the speed sensor was located on the front wheel ?? If there's a wire on the swing arm it must attach to a sensor where ...on the swing arm ?
DarkStaR
« Reply #18 on: June 11, 2008, 10:34:00 PM »
I don't think this is the problem, but:
It's on the rear swingarm. Follow the wire or look near the brake rotor bolts.
Super T.I.B
« Reply #19 on: June 12, 2008, 02:22:41 AM »
Ok, my cluster did sort of the same thing on my 620, but the needle was stuck on 11000 rpm when it wasn't even running.
Took it back to the dealer and he said the gauge cluster had a common problem with all current (before 696) Monsters. He pointed to a S4R and said that one needed to be done too.
He took it off and put a new one on, under warranty.
So, take it back to be replaced.
 Wink
DoubleEagle
« Reply #20 on: June 12, 2008, 04:54:34 AM »
 Wink
        Sorry to hear that !... I was hoping to fix it myself. Thanks for the info though.......DE
DoubleEagle
« Reply #21 on: June 12, 2008, 05:41:30 AM »
UPDATE: Just got off the phone with my local Dealer /Service Mgr. , he finally returned my call. He said he was going to order a new gauge package, that they can't be fixed........so much for that story for now. Just have to wait for Ducati which we all know might take 'til Thanks Giving.
Pages: 1 [2]   Go Up
