Park in N?
Started by rideserotta, December 17, 2010, 06:49:08 PM
rideserotta
When you park your bike do you leave it in gear or N? Do you back in or not?
When on flat ground I pull straight in and put the bike in N. On a hill I leave it in gear. I back in if after parking I'm pointing uphill.
'07 Ducati GT1000
'05 Ducati Monster 620 - Sold
redxblack
Scotzman
There's enough questions here for a survey, but always in gear and as far as direction of parking- depends where I am.
Kopfjäger
hbliam
#4
N
Parked so I can pull straight out when I leave.
I don't (rarely, if ever) park on hills.
sugarcrook
In gear.  Let your bike get away from you one time at a gas stop and you'll always kill your engine with the kickstand.
2013 BMW R1200R
2008 BMW K1200GT (Traded)
hbliam
Quote from: sugarcrook on December 18, 2010, 12:10:10 AM
Conversely.  :)
In neutral. Let your bike get away from you one time, when you forget to pull in the clutch prior to stabbing the starter and you'll always shift to neutral prior to shutting down.
Kopfjäger
He said parked, what are you talking about?
justinrhenry
always in Neurtral... the backing in part depends on the situation.
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
Bishamon
Neutral, unless I am on a slope, in which case I park nose up in first.
2011 Monster 796
2007 Sport 1000 SE (SOLD) :(
redxblack
If you always park in gear, you'd be less likely to forget to grab the clutch. I also lock the forks unless I'm parking in my garage.
Monster Dave
Always in gear. Always with locked forks.
z0mb1e_DUC
In gear, nose out, on flat ground, if I can.  I also always pull the clutch in when I start.  I've had old bikes drop into gear when I tried to start them.  A couple of thumpers and an old ATV have done it to me.  Only took once of chasing a bike for me to make it a habit.
'09 m696 Dark
Cloner
Try this on any of my bikes, including both Ducatis, and you'll NEVER get the bike to shut off.  I promise.
I typically park in Neutral unless on a significant incline.
Let your bike get away from you one time at a gas stop and you'll be embarassed into learning how to manage your bike....regardless of what gear it's in.
'64 Ducati Monza 250
'00 Aprilia RSV Mille
'03 Ducati 800 SS (race bike)
'04 KTM 450 EXC
In gear.  I don't get why you would ever leave it in Neutral when parking.  Why are people doing this?  I didn't know this was something people do.
