February 13, 2025, 10:20:45 AM *
Author Topic: Choke or Fuel Enrichment Circuit?  (Read 2884 times)
speedknot
If a Honda= rice burner, then what is a Ducati?
« on: December 17, 2010, 07:27:06 PM »
Does anyone know if my 01 M750 has a mechanical choke or a fuel enrichment circuit?  When I choke it I don't see the gate through the intake.
2001 Duc M750, Harley Forty-Eight, 1976 Honda CB400F-SS, 1975 CB360T
« Reply #1 on: December 17, 2010, 07:37:09 PM »
Most of us (including me) and Ducati call it a choke.  So do the Brit car people with SU CV carbs.  We are wrong.  It is indeed a fuel enrichment circuit.
speedknot
« Reply #2 on: December 18, 2010, 07:13:55 AM »
I'm not a big fan this set up.  A few of my other bikes had this and it just didnt work as well as a standard mechanical choke.  I had a hard time starting the Duc yesterday and I'm almost positive it was due to the carbs not getting enough fuel before ignition.  Other mechanics have expressed this notion as well.
« Reply #3 on: December 18, 2010, 08:46:10 AM »
Enrichment devices work just fine.  My bike starts in much colder weather than we are having without problem.  So did our 66 Volvo with SU carbs.  In cold weather, "full choke" is needed.  Check the cable adjustment.  Also make sure you have good spark plugs and good spark.
« Reply #4 on: December 18, 2010, 02:39:00 PM »
I'm guessing it gets very cold where you live as in snowing.
The enrichment circuit on the stock carbs is one of it's best features. My stock carbs fired the bike into life immediately in  zero deg C (as cold as it gets here which is rare). You have to have a good routine to start your bike that easily with FCRs in cold weather.
Give that carb a good clean and check for other reasons why you have hard starting. Like fouled plugs, old ignition cables, jetting not suited to your mods, weak fuel delivery, etc.
When it's very cold, do you have carb freezing also?
speedknot
« Reply #5 on: December 18, 2010, 06:45:42 PM »
My new garage doesn't have heat yet but it seldom gets below 40*.  It's insulated and attached to the house.  The carbs shouldn't be freezing.  I have a feeling the hard starting is due to it sitting a few weeks at a time.  I also had this issue with my XT225 until I changed the carb to a Mikuni TM33 pumper.  I checked the plugs on the Duc and its getting plenty of spark.  Weak fuel delivery seems like an issue.
This is one of those mystery issues that I would spent hundreds for a mechanic to troubleshoot and never have it resolved.  I'll just chalk it up to a "temperamental european machine".
« Last Edit: December 18, 2010, 07:35:01 PM by speedknot » Logged
« Reply #6 on: December 19, 2010, 04:25:09 AM »
Have you checked to make sure the cable is adjusted so it actually lifts the plungers and that the passages in the carbs are clear to allow fuel through the enrichment circuit?
My 900 starts at 32 if the battery is up to it at the time.
OT
Still Sweeping.....
« Reply #7 on: December 24, 2010, 09:01:27 AM »
FWIW - my 2004 M1000 (EFI with manual fuel enrichment) starts fine at sub-freezing temps.  Also stored in a ~40F garage with battery tender all winter....
« Reply #8 on: December 26, 2010, 01:13:20 PM »
The cold start lever on an efi bike only raises the idle.
speedknot
« Reply #9 on: December 26, 2010, 06:29:24 PM »
Smarty pants! Grin
OT
Still Sweeping.....
« Reply #10 on: December 27, 2010, 11:34:08 AM »
So, that's why it's called the "Fast-Idle Lever"..... Tongue
Frankly, I prefer having some semblance of manual control over this, rather than relying on sensors....
« Last Edit: December 27, 2010, 11:36:27 AM by OT » Logged
« Reply #11 on: December 27, 2010, 12:34:04 PM »
Your bike starts at sub freezing temps.
Why screw it up?  Grin
