February 07, 2025, 01:12:26 AM
Brake line compatibility?
Topic: Brake line compatibility? (Read 2281 times)
Z06C5R
December 20, 2010, 08:37:26 AM »
So I just switched over to a set of MW no-rise clip ons on my '01 750, and of course ended up with gobs of extra brake line. I'm looking for an OE set off another Ducati that will fit better, since they're already stainless and I'm not keen on spending for custom lines anyway - I did a little bit of searching, and it looks like lines off of the SS models will work, no? Any other models to be on the lookout for? I'm assuming I need something with a single line at the master, and a T-fitting somewhere in-line, right?
'01 M750 "dark" (now red)
atomic410
steel horse i ride
Re: Brake line compatibility?
December 20, 2010, 09:54:49 AM »
I know you siad that you don't want custom lines but when i went from the 1 to 2 split stock line to 2 seperate lines it made a world of difference and eliminated some of my bleeding issues and problems with air being trapped. just my 2 cents.
Team Atomic Racing Check us out @
www.teamatomicracing.com
Thanks to my 2011 sponsors;
Motorex, Vortex Racing, Sidi Racing, Studio 299, Dunlop, Motoprimo, Caztek, On Track 4 Him, Fix Studio
2009 Framstad Cup winner
2009, 10, & 11 CRA 5 hour endurance race winner
CRA Expert #2
ZARS track school instructor
Z06C5R
December 20, 2010, 01:47:24 PM »
How much did that run you?
xcaptainxbloodx
December 20, 2010, 05:44:05 PM »
useually around ~130$ from spiegler
TAftonomos
is without a monster :(
December 20, 2010, 06:38:15 PM »
Quote from: atomic410 on December 20, 2010, 09:54:49 AM
+1, especially on a track bike.
I'm running the loop line on my monster as it's "cleaner", but will do the split line for the track toy 2vsbk
MyDucParts.com
badgalbetty
its never too late to be who you might have been
December 21, 2010, 05:54:06 AM »
you can make your own brake lines. Goodrich ooffers all the parts you need. Just measure and buy. I had separate brake lines on my bike. Made a difference..... front brake was more responsive as I noted in a previous thread.
atomic410
steel horse i ride
December 21, 2010, 08:15:45 AM »
Quote from: Z06C5R on December 20, 2010, 01:47:24 PM
I can't remember but i think it was around $75 a line with fittings. I had some motor work done last year and the shop said your brakes suck, we recomend different lines, i said yes and i just wrote the check and looked the other way. #1 racer skill is writting a check and not thinking about it.
CRA Expert #2
Z06C5R
December 21, 2010, 08:25:09 AM »
Not as bad as I though. I was seeing regular aftermarket stuff in the $2-300 range, so I figured custom would have cost a premium over that. The problem I run into is that I'm still buying up the gear I need for myself to ride this thing, and I'd rather not skimp there - So when it comes down to safety vs bling, it's a bit harder just to cut the check and run.
If I wanted to run 2 separate lines from the master down (right?), will my old-skool coffin master move enough fluid to keep things nice and firm? Considering the overall line length will presumably be a good bit shorter than stock, I'd bet the extra length added by the 2nd line would be negligible, no?
atomic410
steel horse i ride
December 22, 2010, 10:40:43 AM »
doubt a really nice set up will be more than $200. I have one where the banjo pivots and costom color etc and it wasn't over $200. it will make a world of difference and you can't get better safty equipment than properly working brakes imo. and yes your stock coffin will work fine. too many people are down on the bulletproof coffins. take a look at most AMA supermoto set-ups they use them and if there is gonna be a problem those guys are gonna find them. find a race shop in your area and have them do the lines. race shops do that all the time and know how to make them or order them correctly with the right fittings. every major city has a race shop. dealerships probally will charge you more and keep your bike in the time it takes to order.
CRA Expert #2
