February 22, 2025, 06:10:33 AM
Rotella T6 5w40 = JASO MA -- anyone use it?
Topic: Rotella T6 5w40 = JASO MA -- anyone use it? (Read 4076 times)
December 29, 2010, 08:12:19 PM »
In my eternal quest for alternatives, I noticed that Rotella T6 has a JASO MA cert listed. It's a 5w40 full synth -- has anyone used it?
Just curious, I think the 5 would be ok in the wet clutch models..
Re: Rotella T6 5w40 = JASO MA -- anyone use it?
December 29, 2010, 09:27:48 PM »
The idea of a 5W in an air cooled bike (unless you live in Alaska) doesn't thrill me.
booger
December 29, 2010, 09:51:45 PM »
I ran that stuff all summer once, and rode the bike hard. Never had any problems in the wet clutch engine, although the tranny shifted like it was running on a thinner oil; shifts were louder and clickier. It's got a great additive package designed for keeping heavy soot particles in suspension in diesel engines, neutralizing acidic byproducts of combustion, and also has a zinc presence that's good for addressing wear on metal-to-metal reciprocating parts such as camshafts and the like. So it's up to the task, and it's cheap, it's syn(although a lower-end of syn), and it's oily. I prefer a heavier higher-end synthetic just because I believe I can feel it buffering the transmission shifts more though.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
monstermick58
December 29, 2010, 10:13:27 PM »
Maybe this may help
http://www.sigmaperformance.com/rockers.html
Mmick
December 30, 2010, 02:21:18 AM »
Quote from: howie on December 29, 2010, 09:27:48 PM
That's my thought as well, but the difference in 10w and 5w isn't THAT great... They also have a 15w40 that is JASO MA as well. My '95 900SS says to use 15w50..
Quote from: monstermick58 on December 29, 2010, 10:13:27 PM
Maybe this may help
Help what? Fill space? That doesn't address this at all, they didn't use Rotella T6 and that problem has been around for ages -- I've seen 100% dealer serviced bikes end up with flaky rockers -- dealer serviced using spec oil.
Mobil1 4T is JASO MA as well. I would expect a similar profile given the cert.
J5
I'm here to fix zee fridge
December 30, 2010, 02:42:42 AM »
Quote from: ducatiz on December 30, 2010, 02:21:18 AM
from what i read it states to use 50W not 40W
December 30, 2010, 04:48:01 AM »
Quote from: J5 on December 30, 2010, 02:42:42 AM
the oil that comes in the current wet clutch models is 10w40. what "it" are you reading?
December 30, 2010, 06:14:22 AM »
My concern with the 5W is that air cooled engines run larger clearances due to possible expansion in some critical areas like piston skirts. Transmission shift quality could be an issue, but if it is an oil change would fix that. Since the T6 is MA rated I would not worry about the clutch. I must add my tendency is to be rather cautious when the repair costs can get rather high as compared to savings or convenience.
The 15W-40 is not synthetic if that matters to you. People have been using the Triple T in bikes for years
December 30, 2010, 08:00:14 AM »
I thought there was a synth 15w40
monstermick58
December 30, 2010, 05:56:09 PM »
Sorry ducatiz, I know my point was a little left of field, it was the point of using a 5w-?w oil and having rocker arm problems as I was unaware of this problem.
Please continue............
Mmick
December 30, 2010, 07:49:42 PM »
Quote from: ducatiz on December 30, 2010, 08:00:14 AM
I just googled Shell Rotella to be sure:
http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/products/zzz_lhn.html&FC3=/rotella-en/html/iwgen/products/t6_detail.html
I think they are missing a major market.
